Hey ok i have a 1997 r33 which i bought as a shell which was in an electrical fire and is a repairible write-off, i have almost finished building it up but my daily driver is starting to die n needs some love and i dont have any spare cash to finish this.
Its almost finished being repaired, i had to completely replace all rear end parts tail lights, rear bar, boot, i put in an manual rb25de as i had it lying around, would be perfect for rb30det conversion, the shell was a turbo shell so has 5 stud 17X9's which need new tyres, i have replaced wiring looms but some wiring still needs to be done, complete dash, aircon, heater box was replaced, engine bay was stripped to bare metal and sprayed gloss black looks hot as,
Still needs front widscreen, front gaurds, headlights, clutch fan, and some air con bits if you want aircon,
front bar is gtr style but needs some fiberglass work, also needs full re-spray as its in 2 diff colours atm
Have bonnet but corners bent may be fixable i dont know
i have got urethane gear box mount, diff mounts and sway bar mounts, interia is immaculate condishon, body is very straight.
does need viv but i can provide a tax recept for the car with the work for ease of this.
Looking for $5700 will consider swaps for cheap turbo manual, r32,33,silvia, 180 ect with some cash ajustment, would concider including my daily with a swap 1990s auto pulsar q, needs t/belt waterpump n driveshaft boot with 11 months reg
Im in SE melb neer knox city
pm or msg me 0401011380
cheers Jarrod
PRICE DROP TO $5000
Now includes turbo conversion, walbro fuel pump, fuel pressure reg, thick alloy radiator, and black HKS front mount cooler kit
Also on ebay
Edited by unarmed_skyline
https://www.sau.com.au/forums/topic/197561-1997-project-r33/
hey, i have all the parts sitting around minus intercooler, injectors and ecu, to convert this to turbo if anyone interested in that.
im working nights so can view most times.
cheers Jarrod
360 veiws and no interest?? i've got lots of spares for this car, if someone buys it this week ill throw some wide fiberglass fenders and mabye black hks front mount cooler kit with stock piping location, for $5000, would mean only things to get in on the road is headlights,clutch fan, windscreen and respray, and ecu, this combo made around 170kw at the wheels with only 5psi on r32 turbo with full boost by 1800rpm on microtech ecu, will consider selling with microtech for $6000.
I need this gone so i can repair my daily
oh forgot to saw got, walbro fuel pump and adj fuel pressure reg,
pics with gaurds and front mount
hey Jarrod,
thanks. i dont think you should lower your price any more...$5000 is a fairly reasonable. you should try chuck it on ebay instead- pretty soon im going to do so myself.
cheers Marlon
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
