Need some advice.
last weekend i was driving and i saw my oil light flickering and the engine started to sound like a diesel engine, so i parked the car and let it cool down and then checked the oil and it was full, so i went home and did a change of oil and filter, started her up and the problem looked like it was fixed, so i took her for a drive and i noticed that when the temp. reached 1/2 it started to do the same thing. My feeling is that the oil pump is on its way out, so as the engine gets warm the pump starts to shut down. Anyone every had this problem? Am i thinking along the correct line or is there something else wrong with the engine? Any help would be good
p.s. its a rb20 single cam engine
Thanks
Edited by who's next
https://www.sau.com.au/forums/topic/197585-a31-problems/
to take the sump off u can either pull the engine out or if you have access to a hoist support the engine using a special support bar and chain then drop the crossmember off, i know koz i did this myself on my 32 koz it had the same problem but after cleaning out the sump an removing the oil pickup an replacing the gasket it was fine, it only made it easier for me being a mechanic so i could easily drop the crossmember without takin it right out, by which is a total biatch to get back together
https://www.sau.com.au/forums/topic/197585-a31-problems/#findComment-3535648
I used this opportunity to tell the wife i might need to change my engine and to convert my car to a project car (as i would like to do everything meaning and build up a good strong car), so i went by a guy who brings in used parts from japan, and told him i was interested in going with the rb25det set up. I had my heart set on the neo rb25det, but he told me that engine is trouble and to go with the rb25det with the ignitor. Now i have been searching on the net to see people's experience with both engines, but i have not seen anything bad about the neo. My thinking for going with the neo is that its a newer engine which should = less miles and its rated at 280hp the same as the rb26dett (without the cost of the rb26).
Have any of you guys had a bad experience with the neo?
Which one would you suggest neo or non-neo
thanks.
https://www.sau.com.au/forums/topic/197585-a31-problems/#findComment-3538146
Thanks guys, I would go with the neo, its 3,000.00 more than the non-neo. I think this guy brings in good parts, i have bought parts from him and so far no problems. So my baby would be out for a few months as i plan to do it like a project car (diff, fmic, suspension etc.) every month i would buy something and put on before the engine goes in, that way i would have a good strong/safe car at the end of the build. would take pics and step by step and post it when she's done.
Thanks again
https://www.sau.com.au/forums/topic/197585-a31-problems/#findComment-3540234
this down in Trinidad and Tobago so that's TTD so the non neo would be 12,000.00TTD and the Neo is 15,000.00TTD, now you could get it for less but this guy brings in good engines and i think its better to put the extra to get a good engine, plus if there are any problems he does not give trould to change the parts. yeah things down in trinidad real expensive.
https://www.sau.com.au/forums/topic/197585-a31-problems/#findComment-3553276
i put a rb25det s1 in my cefiro, whole time i planned to run a neo or even 2j but when it comes down to money you can only do so much.. if you stretch your budget too much you'll end up with a dodgy set-up rather than something similar thats very reliable
s1 or s2 ftw !!
https://www.sau.com.au/forums/topic/197585-a31-problems/#findComment-3567715
    • I鈥檓 interested in the carbon diffuser fins and Toshiba MFD screen replacement if they鈥檙e still available.
    • @GTSBoy yeah i know it was not the "great" idea but it is and option...but i think i will stay on no BoV rather then trying to make it work with "half" this and that. But that GReddy FV2 is cool...i like that you can make it like stock if you want (and have/make the custom pipes) For other thanks! it was alot of information. But for the sound...a dont rly "like" both of them...specialy if they are loud...but if i "must" choose i would rather have little whooosh rather than sutututu with no BoV....BUT that is what is i gonna get. So for the all info i gather. In my case:  No BoV is not that bad cuz it is stock...and iam used to put N/clutch right after rpms are around 1000 so it should be ok...just need to avoid "big" drops. But i do not have the engine in the car so i do not really know how "bad" or good it is. But as i had that little test drive it looked ok. The atmo BoV should be worse car would dump to much fuel specialy between the shifts...so without proper tune/ECU i dont want that. BUT with that...car should drive ok with no problems right? (i do like there is less piping wih this solution) 馃檪
    • Usually an RB20 won't stay in closed loop idle anyway. The O2 sensor gets too cold, stops swinging.
    • They aren't, but it depends on what interests you about an R32-R34. If it's the front engine I6 turbo that tunes well with a manual transmission an E92 335i 6MT is so incredibly cheap. You can get a super clean one for 20-25k USD tops. Put an LSD in it, tune it, have fun with it. If it's the general idea of AWD + turbo and a manual transmission the 996 Turbo is absolutely much more expensive, it's less practical but it's also basically a complete track-ready car from the factory. At least the Mezger doesn't have heaps of oil control issues. And in the US the 996 Turbo and R33 GTR are roughly the same price these days. 996 maybe a bit more now that the hype has abated for old Skylines here.
    • these are not the same
