alrite guys,
ive ridden my R33 skyline off. there are some parts that i still have lying around, insurance has the car so what i list for sale is all that i have unfortunatly.
ITEMS LOCATED IN RESERVOIR, MELB. PICK UP IS OK CAN ORGANISE POSTAGE FOR SMALLER ITEMS BUT LARGER ITEMS FOR PICK UP ONLY
Item:
Trial Rear bumper bar
new
Price:
$250ono$200 firm
To Fit: (What car)
R33GTST (series 1 or 2)
Comments:
Bar is still in bare white gel coat. needs to be lightly sanded and sprayed.
Item:
R33 Rear Spoiler
Condition:
good
Price:]
$100$60
To Fit: (What car)
R33
Comments:
series 2 rear spoiler in QM1 white. good condition, but would need a cut and polish to make it immaculate. all leds working
Edited by cheez
have you test fitted the side skirts and do they need much moudling or should be a virtual straight fit??
i too would like to know this. and would you post side skirts to gold coast?
would prefer to sell in vic but if buyer is prepaed to organise their own postage i will bubble wrap and box the larger items for you.
they are very near a straight fit, they will need drill holes put into them for screwing on.
