Alexis85 Posted December 14, 2007 Share Posted December 14, 2007 so i have this new problem thats was intermitten but now seems consistant anywas its having truble reving past 5000 rpm under load (like 3rd and 4th) and it sometimes has a small back fire, and pop but other then that it seems to be running fine... any ideas? thanks Link to comment https://www.sau.com.au/forums/topic/197629-having-trubble-reving-past-5000-rpm-under-load/ Share on other sites More sharing options...
H@ME Posted December 14, 2007 Share Posted December 14, 2007 there will be many people on here that can solve this problem however jsut to get the ball rolling, possibly your AFM (air flow metre) folwing and therefore the ecu is 'retarding' the way it drives. also possibly your spark plugs are old or coils are not up to sctach, that would probably explain the missfire, here is just some ideas...get the plugs changed over, check the terminals on the AFM and make sure coils are all working fine. hame Link to comment https://www.sau.com.au/forums/topic/197629-having-trubble-reving-past-5000-rpm-under-load/#findComment-3532620 Share on other sites More sharing options...
lighty01 Posted December 14, 2007 Share Posted December 14, 2007 could be boost leak Link to comment https://www.sau.com.au/forums/topic/197629-having-trubble-reving-past-5000-rpm-under-load/#findComment-3532644 Share on other sites More sharing options...
TTT Posted December 14, 2007 Share Posted December 14, 2007 since it is an R32 and not R33, it is not rich and retart. your problem will most likely bee spark plug or coil pack related. easy fix. 6 new spark plugs - $24 Roll of good quality Electrical tape - $5 Gap the spark plugs to 0.8mm and put them in (search this forum for the part number of the spark plugs to use) tape up the coil packs which are already out to get to the spark plugs (search this forum for detailed instructions) done. 2 hours and $30 (it may take you less time) Link to comment https://www.sau.com.au/forums/topic/197629-having-trubble-reving-past-5000-rpm-under-load/#findComment-3532652 Share on other sites More sharing options...
Alexis85 Posted December 14, 2007 Author Share Posted December 14, 2007 Hey thx i'll check them anyways the plugs are farly new and i already checked for a boost leek and nothing.... is ther a way i can check the coils? Link to comment https://www.sau.com.au/forums/topic/197629-having-trubble-reving-past-5000-rpm-under-load/#findComment-3532702 Share on other sites More sharing options...
QUICKY Posted December 14, 2007 Share Posted December 14, 2007 ide bet on coils Link to comment https://www.sau.com.au/forums/topic/197629-having-trubble-reving-past-5000-rpm-under-load/#findComment-3533139 Share on other sites More sharing options...
TTT Posted December 14, 2007 Share Posted December 14, 2007 Hey thx i'll check them anyways the plugs are farly new and i already checked for a boost leek and nothing.... is ther a way i can check the coils? if it only happens under load, then you could only really check them on a dyno. Just tape them up as per instructions in many other threads.. Here is one I bothered to type it all up in http://www.skylinesaustralia.com/forums/in...t&p=3202123 Link to comment https://www.sau.com.au/forums/topic/197629-having-trubble-reving-past-5000-rpm-under-load/#findComment-3533626 Share on other sites More sharing options...
