just finished the fibre glassin bit, painted and put in, fits snug bolts at bottom of it. just got to finish the top cover for it, going to make it out of tin and its going to cover the whole corner of the bay.
what do you guys think any good ???
its in a r32 gtst
Edited by jimme85
yeah im makin the top out of fibre glass as my sis chucked out a bit of ali sheet i was going to use, il make the mould out of cardboard on the car first then the fibre glass goes on ;) then some insulation inside the walls, then to find a scoop to bring the air from front of the front bar in to it.
i like my apexi pod love the sound of it when boosting :( rather it than the stocky not so cool lol
that's pretty cool mate..
I'd say that the one I had is a shit load better though..
what do you rekon?
http://i35.photobucket.com/albums/d158/T_T...20gtst/R327.jpg
Is that just a GTR airbox?? Is there an inlet underneath it?
tops finished >_< painted but not in the pic, now just got to insulate it now :P
Looks good mate, congrats on having a go at something and not just getting on here every day bitching about the price of this car or that car, someone running an atmo bov or someone not using the stock airbox. Very refreshing :P
every one bitchin about some thing on here lol, cheers man fibre glass was pretty easy first i made a mould for it out of card board built it around the pod in the car by tapin it all together with makin tape, then i pullin it out as one unit, then i layed the fibre glass on it and coated in in shit loads of resin, dryed cut the edges to right size and presto the box was made >_< plus its got two inlets into it the stock one and the stock intercooler pipe as well
nice and happy now :P
Edited by jimme85
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
