Yeah, always a good idea to upgrade the turbos considering the issues stockers have with lots of boost and age. I'd do:
Turbos
Injectors
Fuel Pump
ECU
Exhaust
AFMs (depending on ECU)
EBC (depending on ECU)
And then you need clutch etc.
I've been told you can get very close with stock injectors but I have no personal experience with this.
For that kinda power i'd be upgrading the fuel system and turbo's whether they can make it or not...
its like driving without insurance... Cheaper, but a huge risk
300rwkw isn't too hard.
Full Exhaust, PFC, injectors, 1.2 bar. I reckon this will give you 290ish 300rwkw.
Twin GTSS will give you that easy imo. ;)
I wasn't saying its difficult.
Out of that list, only the exhaust would be what I would consider "minimal" or "basic" mods.
Turbos and ecu are a more serious modification IMO, requiring a lot more work and it will also change a lot of things about the car.
Dont the stock turbos still have ceramic wheels and hence the ~14psi limit before they go bang? This is the reason I said it cant be done with basic mods. :( Of course it can be done without much difficulty, but it all comes at a cost. :)
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
