sure it's OEM front bar? fits well at the ends (where it usually overhangs) could be East Bear?
its not OEM, its still got standard GTT guards so its impossible to be OEM. if they were OEM the front bar wouldnt even fit on the car with the narrow gtt guards. the question is if the front bar is a East Bear(ud have the best bet of telln ss8) or some jap copy.
  • Replies 70
Andru, a lot of people, especially in HK, can't be f*cked mucking around with the GTR bumper and just bolt it straight up and just squeeze it on there, but always looks weird....
you can cut it in half, narrow it, and then plastic weld back together (in theory) there-by having the bumper fit the guards better, but i've never "knowingly" seen a GTT with that done.
If it it has the whole lower lip/spoiler section AND fit well at the guards, does kinda tend to mean it's East bear.... too hard to tell without looking at it in the flesh
realli??? i wasnt aware of that? the gtr bar sticks out quite a bit, shaving and bending a bar so much i would of thought it would cause alot of stress to the bar making it very weak.
but if it does the job then npz i guess lol. i havnt realli aligned a gtr bar onto a gtt but im aware its a big diff in size
about it being east bear or not, wat i was trying to say is i cant tell, because ive never seen em in person, but u never know if its a custom one off or something u no? thats why i said ud be the best person to find out if it was or not since u have one.
Edited by R34NRG
I rekon this car looks ace! Even better if its an East Bear item, the GTTs look funny when they have GTR front gaurds because they dont suite the fat ass rear. Knowing its a chicks car makes it even hotter, Would be awsome seeing you in this Ferah :banana:
Brad.
LoL i know but it leaves in January! So by the time it gets complianced and rego'd...who knows!!
Hey got piks of the rims? If u want PM them to me, i may b interested in buying them..
Don't have pics Ferah.. there at the workshop. Called Work VS or sumthing with 5 spokes. Probably abit wide for the 34..but i'm sure u can go wide-body to make them fit! :banana:
Tai im going to have to swing past then :thumbsup: to check em out!!
and R34NRG and ss8 gohan, I was told it was an original front bar. So as ss gohan has already stated, they have obviously cut and chopped the bar from the middle to make it fit. They told me its not fibreglass and is made of plastic. So weather its a GTR bar or an east bear bar its one of the two i guess
  • 3 weeks later...
Nice car......
I assume you've got a compliance workshop already, but if you don't we can give you a good deal, and we have all the stock parts you need. (we swap during compilance for free, we don't pull b.s. about tyres, extra charges, etc.).
Give us a call at our showroom 03 9415 7150 if you're interested. (ask for Jon)
cheers,
david @ carizma
Haven't heard about any changes.....usually people put Halogens on for compliance and registration, then swap them back.
what's the go with Xenon headlights these days for the R34, i heard something was going to change in regards to compliance for them?
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
