Just a heads up guys.My son purchased my R33 GTS-T off me when I leased a ForesterXT. Gee I loved that car. Anyway. He drove to golf at Kogarah Golf Course on thursday to play with a mate. he came back to it at 2.15pm and noticed the drivers door was unlocked. On opening the door he found the ignition switch was smashed on the floor but luckily nothing else but some coin and sunnies taken. It looks like the immobiliser stopped them getting away with it. The disturbing thing was they got in without damage to the locks or windows. We got it flat topped home . We were a bit suspious of a car that turned up and parked just opposite and watched us unload the car.I spoke to a mate who is a cop and gave him the rego of the car, though my son found out where the car is from and so we don't think it had anything to do with the attempt
We got a new barrel for the ignition and all is good. While talking to my local import shop they had heard of at least 6 cars stolen in the shire recently.
https://www.sau.com.au/forums/topic/197721-be-careful-out-there/
disable the door unlock button thingy on the drivers side of the car.
+1.. If it isn't disabled, that is exactly how they unlocked the door without braking anything.
It's very easy to slide a shim between the top of the drivers glass all the way down to the button and click, passenger door unlocked.
damn you guys have alot of theft up there in nsw :D
NSW sucks balls.
Skyline owners, actually anyone that owns something of value to thieves, unfortunately need to take precautions.
Alarm, immobiliser, where we park and at what time.
Even then a car can still be stolen.
Walking ftw :dry:
Cut the brown wire. This will disable the switch to open the passenger door. You will still be able to lock the passenger door with this same switch, but not unlock it.
As 'Pauls33' has stated in his DIY thread, the R33 and R34 GTR switch wires are also brown.
i put electrical tape over the button and put some plastic lid to block the button from being pushed up!!
dodgy diy for me ><
trying to find some other method without cutting the brown wire ><
maybe like a cap for the button?? any ideas ?!?!
Is it the same on a R34 GTT?
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
