this has been covered a lot.
If u mean extra work as in cutting off and welding up the 4wd transfer case, then yes a bit of work is required. Plus the fact u are replacing it with an older box.....
sorry mate i searched the site for about 3 hours last night trying to find a post about it
I immagine that a 32 box isnt going to deal to well with the tourque of a rb25, its the tourque that kills gearboxes afterall, not power
I don't know about that. I'm running a RB25DET in a 32 GTS4, through the original gearbox, and the 'box is holding up fine.
  • 3 weeks later...
i read those threads URAS, pretty interesting.
i still have one question though, which gear box is best bang for buck, and strong enough to handle say 350rwkw.
from reading that i gathered, gts-t boxes are more expensive then gtr boxes, and that gtr boxes are hard to get to fit gts-t's. would it be worth making a rb26 box fit a rb20? or would it just be better just to throw a rb25 box in.
ps. will the rb25 box be just as strong as a 26box?
sorry for the noob questions, just curious to know.
thanks, issa.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
