Hi guys,
I bought a rb25det engine with box for my S13!!
I am looking for over 500hp for drag strip and everyday car!
I will for the begining that I don't have much money to spend and I also want a safe motor!
Where is the limit of the stock pistons? How much horses can handle with good rich mapping (high 11 afrs?) ?
And where is the limit of the stock rods? How many rpm can handle and how can I avoid any damage of them with my driving?
Can I strengh the rod's limits with changing the bolts with arp? I read somewhere this but please confirm this to me :blush:
I will work with stock cams and head!
The parts I will order are:
Greddy style intake
Q45 throttle body
XS Power top mount manifold (I will increase it strengh with a "help bar" and some extra welds)
JUN Crank Collar
N1 oil pump
Tomei oil gallery ofrice (and I will block one oil feed and I will increase the flow of the oil return)
52mm koyo style cooler
I have fmic from my previous motor with core 600x300x76mm and if you think that it isn't enough I can put a same with 100mm core!
I am from Greece and the climate here is quite hot.
My exhaust is 3"! Enough?
I have walbro fuel pump and as I read I need a fuel pressure regulator because stock of rb can't control the big fuel pressure of the walbro!
555cc injectors and 300zx maf and remapping the stock ecu.
And I will try to buy a twin plate clutch kit instead to buy a single ACT even then I read that act can handle 500hp!
If I will buy a twin plate maybe I will buy
Also I bought a gasket kit to replace everything! Also head gasket I will leave the stock.. what limits it have? I read something for 1.2bar boost!
I don't know yet what turbo to use....!
Garret choices:
GT3076 I think that with this I couldn't go more than 520hp..
GT3582 Garret says 400-600hp according the housing...!
Greedy TD06 25!! At 1.15bar with absolutely stock motor got 500bhp!!
Anyone knows how much more can go with more boost?
Turbonetics GT-K 550!! I love the look of this turbo! :banana: 500-600hp rated!
Also any help with the garret turbos what horsepower you can think that can give with the same boost to compare and with what compressor housing? (1.1-1.2 bar)
Garret's are also cheaper choice!
Also please tell me your comments for my choices, tell me what else I will need and help as much as you can :banana:
Edited by GreeceS13
https://www.sau.com.au/forums/topic/197729-rb25-setup-help-for-over-500hp/
I dont think 500hp will last long on stock internals, i hope thats a metal head gasket.
At least get forged rods and pistons, and balance the motor.
I would go with a GT35R or a GT3582. With a .82 housing, ur 3 inch will be fine.
You should get the power with standard cams, but i would definately get some minor head work done.
Edited by subzeroR33
500hp at the crank is approx. 270-320rwkw, depending on drive train and friction etc, its way too variable to put a hard and fast figure on the conversion from chp to whp.
But a std motor will handle up to 300rwkw, but when you get to that level its a roll of the dice as to how long your motor will last.
But I don't care what you say, DA is correct, it'll cost you heaps..............its reality, you can't avoid it.
Ok maybe it will cost and more... but I don't ask you tell me how much will cost!
I ask many questions... can anyone reply me please?
Please I need replies in all of my question... they are very important for me..!
Also I need ecu as my tunner said me that it cannot remapping the stock..!
Emanage choice is good? Can I have launch control for drag strip? Can it increase rev limiter (because a friend told me that it cannot)? Also I don't need 300zx maf right? Can I run with only the map sensor or it needs the stock maf?
Edited by GreeceS13
just buy a GTR with the amount of money u have to spend to get the power u need.
"I will for the begining that I don't have much money to spend and I also want a safe motor!"
If you dont have enuff money to spend why u telling people no to tell you about prices. They are being realistic and have obviously gone down this path before. If you dont have 10-15k to spend on the car then why bother even thinking of doing it.
To me it all sounds like a lil kid with a big dream, and then he wakes up with his pants wet.
Im not very good with crank horsepower as it doesnt mean shit to me, but personally i wouldnt bother opening up the engine so your going to save a bit of costs there. If it does go bang rebuild it with forged bits. Personally i dont think you will have any issues with it.
They run 9.1 comp ratio which is nice and high, so in my opinion run a gt3076 (.82) with upgraded injectors, pump etc and a good computer without an afm
A friend here is running 270kws at 14psi on a stock as a rock rb25 so its very doable.
Start off with running that turbo on the standard exhaust housing and i think that should get near your power goals without being that expensive.
Edited by SirRacer
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
