  • Replies 44
Nice job on the black munchstagea, I must say I rather like it like that. Can I ask for a tip in how you got the black to look so good? When I go black, it never looks quite right. I'm not very good at photoshop, and am probably doing my colour changes the wrong way as mine always dont quite look right.
Cheers
Cheers
Going from Dark to Light or Light to Dark is the hardest colour change to achieve because light naturally interacts completely differently with the 2. Having said that, the only thing I have done is used a "Levels" adjustment layer while masking out the section I want to effect. If you want to try it, the settings I used for this image were:
Channel - RGB
Input levels - 57/0.29/255
Output levels - 0/128
The key here is the output levels and the fact that I am pulling the white out of the image, once you do that the rest is trying to balance the highlights back in there. I hope that helps.
Cheers
Luke
Ahhh thanks for those tips Luke, should come in handy. I know what you mean about the light interactivity, with the original 3 pics I pic, you'll notice the blacks have reversed reflections, not sure how I did the second one, but it does look better, but I couldn't replicate the same effect until your tips, so thanks for that. I just fiddle until things look right!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
