I'm looking to replace my tail lights with the cooktop/ hot plate tail lights.i'm thinkin there must be importers out there who visit wrecking yards for parts. Is this so and does anyone know which company may do this?
https://www.sau.com.au/forums/topic/197753-importing-c210-skyline-panels/
http://page10.auctions.yahoo.co.jp/jp/auction/m49116431
Should be about $130 + shipping and commission
and the centres to go with them:
http://page10.auctions.yahoo.co.jp/jp/auction/m51270337
$20ish plus postage etc.
PM Laurence He'll be able to buy em and ship them out of japan for you.
Thanks very muchly f/m, getting info like this from the likes of yourself is what makes this site sooo good. I'm hooked on the idea of these lights and will pursue this avenue. Excuse my ignorance but how do I get hold of Laurence. PM is.....???? sorry is he someone on this site?
lol all good, Laurence is one the members on the forum and a resident in japan who buys gear of yahoo auctions for people. PM = private message, which you'll be taken to if you click the link on "PM Laurence". Hope that helps :blink:
Those estimates I posted are very rough and will vary with exchange rate, but they should be in that ballpark.
Im pretty sure that the first link for Yahoo Japan is an auction for headlight surrounds.
Those tail-lights on ebay are out of control. Up to $610 already. Bloody hell.
That's madness! some people must really hate, loath and despise the choc block tail lights. Sure enough they aint sexy, but I can think of plenty better ways to spend that sort of money. For a week or 2 you'd wanna be driving behind your car admiring them and convincing yourself they were worth the small fortune you paid for them, Perhaps they'll increase the value of the car, who knows?
Still haven't heard from Laurence,perhaps he saw those lights on ebay and is flat out rumaging through wreckers yards or doing night raids on street parked C210's, LOL.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
