hmmmmmmm... just thinking y u would think a piece of machinery that has been moving up and down billions of times could never break down, loose its seal...
I would guess that for a given motor, the pistons in the motor would have gone up and down a couple of thousand times more than the piston in the BOV, i know what i would expect to leak first.
  • Replies 149
That information is WAY off..
god there are some dumbshits on here
ok here i go
stock r33 bov which is NOT PLUMBED back so its running into the atmosphere ok
car runs on map sensor and i dont have all the stock plumbed back piping shit so i ran it atmosphere
bov leaks like a heap of shit,must i explain myself any fkn further or are u just another keyboard warrior wanker on here who pays every other c**t to do shit on there car?
thanx good day
ok here i go
thanx good day
Ok, first i'll quote your initial post.
stock bovs are rubbish, leaking heaps of shit, done a trip 2 brissy other weekend, running stock bov, f**kin heap of shit leaking the whole time on light throttle could hear it just in vacum, so fkn annoying
Now for Abu's post in reply to yours.
Now again yours in reply to Abu.
ok here i go
thanx good day
Now I have much respect for you and this will not change my views on you. Same goes to abu, I feel he is a much respected member on this forum and he provides very usefull info and so do you also.
Now you've left out a very important piece of info in you first post and I have highlighted that above. Any person reading your initial post is not going to assume that you ran your stock bov to the atmosphere....thus in your view putting it in the piece of crap catagory.
As others have experienced, the stock bov is not crap if it is used as it was intended to be used, as a recirculating valve. Abu's reply was not out of line.
In fact it was your post that was mis-informing by leaving out a critical part of information.
Explanation and informaton is the key my friend.
So it turns out that it is not abu, but you that is the keyboard warrior today. Maybe your just having an off day, but regardless, the name throwing and "going off" at abu wasn't necessary.
I intend no offence to you by this post.
Thankyou for your time.
Edited by KeyMaker
Fellas, I think we've just gone a bit over board... back on topic...
I need an atmospheric BOV to not stall my car - how to do this?
I need the sucking and shshttt sound... man, I need it bad.
No it will not work.
Your AFM measures how much air is going into the engine, the ecu then uses that measuement of air going in to work out hom much fuel put in.
When you put on a BOV that vents air back to atmosphere (makes thats loud pschhh) your computer (thinking the air is still in the engine) puts in way too much fuel. This results in stalling, stuttering, big black exhaust smoke and a generally shithouse driving experience.
A 50/50 BOV still dumps 50% of the air that the ecu expects, so it still causes a problem. Just leave it stock FFS!
*On a side note I changed my spark plugs on the weekend and forgot to put the BOV return pipe back on, as i changed gears i got the atmo bov noise. But it made the car feel so sluggish on gear changes, spat so much black smoke I cant imagine how anyone could deal with that just for a little ghey sound*
Yeah mate, thanks so much for your advice... it is much appreciated....
You ironed it out nicely - enough said, I concur with your point (and those others have made too)...
That's right fellas... stock then it works and runs better but no sound... atmo BOV and the car runs lean, stalls like shit and performs less efficiently.... ok, I'll go stock... thanks.
have you been reading??
the GFB Stealth-fx does what you want.......................
Apparently it doesn't... as it's only 50 50 plumb back... if I plumb it all back then same thing as stock.
Thanks.
Thanks.
No its not, you can adjust it to fully plumb back or fully atmo, or any config in between. The whole idea of this BOV is so you adjust the volume of the noise you want, i have this on my car and if you set it up right the car doesn't stall on full atmo. I live in NSW and unfortunately it is a defect here, Although i had mine adjust to full plumb back the cop said i could adjust it at any time so defect time. And i too got sick of the noise thats why i had it full PB. I don't know about the laws in VIC.
Full atmo on your bov is just like full atmo on any other bov mate.
PLEASE LOCK THIS THREAD. I cant take it anymore!!!
stolen s15 could you please explain what you mean?
I think you taken my reply the wrong way, i was reply to his post stating that the GFB FX was a 50/50 BOV i was only trying to clear this up by saying it could 100% atmo, 100% plump or anything in beween. I too have gone back to stock.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
