  • Replies 149
^^ Nah he's serious, have a read of his other threads. *shakes head*
Thien, you cant get the sound of venting to atmosphere without the problems that come along with it, unless you change over to an ecu that does not use an AFM.
Thanks mate... and yeah, I'm not too technically-minded when it comes to all this stuff... silly me...
I guess, I'll have to live with it then.... either lose the sound or have the sound with stalling issues.
Thanks mate.
Would a 50/50 plumb back BOV work?
if you really want the psssht, try full atmo on a hybrid type bov. if it gives you trouble in full atmo (which plenty of skylines run without issue) then go 50/50. you should be fine. if that fails, you can always set it up as fully plumbed.
for the guy that asked earlier how its done:
fully plumbed = block one side, attached other to recirc hose.
50/50 = trumpet on one side, other side to recirc hose.
fully atmo = block recirc, use 1 or 2 trumpets on bov
here's mine 50/50
fully plumbed back, as it is now, . the trumpet is replaced with a supplied cap from GFB
btw, if it didnt come with the car, i highly doubt i would've needed or bought it.
Edited by Munkyb0y
here's mine 50/50
Is it just me, is does it seem that most people don't give two hoots about BOV's... and don't car about the ssshhtttt sound... would it be fair to say that everyone is over this?
Or is it due to stalling issues which is common in R33's?
where can you get that done? whats is actually changed?
It's dodgey mate.
you take your stock bov off.
and put it in a VISE.
then crush it a little.
this preloads the spring that is in it which makes it hold more pressure as it takes more pressure to push the spring.
it doesn't actually make any more sound though.
Yes that is correct.
we give no shit for bov sound.
put the stocker on there and stop talking about it.
its true
i also give very little shit for the sound, so i ordered the cap from gfb to block the fuccker off.
i remember driving a 300zx with twin super dooper trumpet ultra mega farkoff bovs. i was over it in 20 mins. i mean even at 2k it was going AAAAAPPSHCOOOO. enough already, i just wanna drive.
Mate, have a think about what youre asking.
Why would you want to modify your car in a way where the *only* benefit will be more noise (which will in turn give you more attention from police), and the downside to it is that it can and almost always will make your car run worse? (In the case of vehicles running airflow metres)
Your stock one does its job, which is to prolong turbocharger life, not make noise.
Dont but an atmospheric one, its pure wank and a waste of money.
DONT PUT THE STOCKER BACK ON MAN.
buy an AEM quality plumb back bov. stockers are shit. they leak and fail to seal. think about it.
what would u do if u were pushed up and down BILLIONS of simes :S
Thanks mate.
No it will not work.
Your AFM measures how much air is going into the engine, the ecu then uses that measuement of air going in to work out hom much fuel put in.
When you put on a BOV that vents air back to atmosphere (makes thats loud pschhh) your computer (thinking the air is still in the engine) puts in way too much fuel. This results in stalling, stuttering, big black exhaust smoke and a generally shithouse driving experience.
A 50/50 BOV still dumps 50% of the air that the ecu expects, so it still causes a problem. Just leave it stock FFS!
*On a side note I changed my spark plugs on the weekend and forgot to put the BOV return pipe back on, as i changed gears i got the atmo bov noise. But it made the car feel so sluggish on gear changes, spat so much black smoke I cant imagine how anyone could deal with that just for a little ghey sound*
This is twice I've seen you post this bad advice.
what is AEM?
stock bovs are rubbish, leaking heaps of shit, done a trip 2 brissy other weekend, running stock bov, f**kin heap of shit leaking the whole time on light throttle could hear it just in vacum, so fkn annoying
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
