  • Replies 149
stock bovs are rubbish, leaking heaps of shit, done a trip 2 brissy other weekend, running stock bov, f**kin heap of shit leaking the whole time on light throttle could hear it just in vacum, so fkn annoying
That information is WAY off..
hmmmmmmm... just thinking y u would think a piece of machinery that has been moving up and down billions of times could never break down, loose its seal...
it makes sense tho. u love dose pipes. so how could u know.
the GFB Stealth-FX is either a full atmo or plumb-back bov, fits the gtst engine no probs
you can adjust it to say 10% atmo and 90% plumb-back
I have one, it is near new and I will sell it soon (repaired the stnd bov)
I run it on my auto rb25det on full plumb-back and it sounds, well, not too bad.
never stalled the engine with it on either, but when you take the foot off the accelerator you can hear the reveberation from the released air hitting between the turbo and the afm.
Nice theory.
and it's good to see that you're brain is at least trying to work.
do me a favour.
ask the brain of yours this question, and then type up the dribble that it gives you.
ready?
"How does a blow off valve work?"
lets hear it?
Edited by GTST
ok..
I'll get you started.
bov has a piston in it.
this piston stays closed, then opens to let the air in the intake out.
it also has a small vacuum line entry point.
bov is placed on the Turbo side of the throttle body.
the vacuum line to the bov gets it's reading from the PLENUM side of the throttle body.
now you take over and explain how it all works.
No googling now.
wish i had the last 3 minutes of my life back.
leave the standard one on.
do a search man..
aparently it is WELL documented that the stock ones are shit and that a good AEM (which is a UNIVERSALLY USED Acronym of rAftermarket Equipment Manufacturer - don't you know anything) bovs are the way to go..
and I can give you your 3 minutes back if you like.
I can travel back in time and take you with me if you like..
I saw a little asian guy do it by shutting his eyes and trying really hard to fart.. then pop.. he disapears and re-apears in the another time..
you want in?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
