the GFB Stealth-fx does what you want.......................
Apparently it doesn't... as it's only 50 50 plumb back... if I plumb it all back then same thing as stock.
Thanks.
It does
I bought one for CHEAP a few months ago, its on my auto mod'd stagea atm.
stnd bov got "repaired" :D
and now that Im on holidays, as of like 1hr ago, Im going to take off the FULLY ADJUSTABLE gfb stealth-fx bov (worth $550 new)
and put back my fixed stnd one
my mack truck is about stealth not sound
contact me if you want it for what I paid for it
I used it on full plumb back and full spring tension, works real nice and sounds, well, funny.
a few test runs would sort out what sort of atmo / pmub back percentage mix works on your car
its not my kinda thing, I got it to hold boost pressure, but Im going about that little quest a different way now so I have no need for this as of next week.
but if you are into bov's, then the GFB stealth fx is worth a research matey
  • Replies 149
It does
I guess, I'll just leave it on Stock then... I can't be bothered, BOV's are so expensive, and the sound that I want is really hard to find... some, e.g. WRX BOV's sounds like a pigeon on steroids... sounds so ghey... I guess, I'll leave it stock... who cares....
Cheers,
you all need to attach a duck call whistle to the end of your blow job valves.
it will solve everything.
ssss quaaawawawawawawa
I gues there's nothing we can do then... Heard you can modify the stock on to make it sound better, but apparently not a good option... never mind... thanks.
god there are some dumbshits on here
ok here i go
stock r33 bov which is NOT PLUMBED back so its running into the atmosphere ok
car runs on map sensor and i dont have all the stock plumbed back piping shit so i ran it atmosphere
bov leaks like a heap of shit,must i explain myself any fkn further or are u just another keyboard warrior wanker on here who pays every other c**t to do shit on there car?
thanx good day
lol well your the dumbshit who is running a plumb back BOV to atmo?
If you had half a clue you'd know the stock plumb back setup returns air into the intake pipe to keep the idle stable when dropping from various RPM.
And you'd also know it circulates air through the plumb back setup to keep gear changes smooth while driving (prevent surging).
Now it does leak air through, but because its plumbed back it all goes back through to the same place in the end.
Link below also shows the fact that the stock BOV DOES leak, is you make it ATMO it will leak into no where.. = loss of boost = loss of power
http://www.skylinesaustralia.com/forums/St...l=stock+r33+bov
So if you don't plumb it back, of couse it will leak idiot thats why its plumbed back in the first place..
Now which moron reroutes a plumb back BOV to ATMO?
Your the dumbshit who has hooked it up wrong, now you blame the quality of the stock BOV saying its shit and doesn't work?
Basically there is nothing worng with the BOV, just your stupid setup.
If you had hooked it up right it would run perfect but because you have hooked it up like a retard it clearly doesnt work.
AND I wasn't having a go at you, all i was saying is that what you stated was incorrect.
The stock BOV will leak when not plumbed back because thats how its designed to work.
Your the one who got abusive :)
Edited by abu
I think CEF11E was runnnig like 19psi on stock R32 BOV with no leaks and this dumbass reckons his is leaking.
Probably not even running close to 19psi either.
THE MAFIA is always saying he is running 20psi with a GT3076 making 300rwkw on a stock BOV with no leaks..
Are you making more than 300rwkw buddy? You must be if your BOV is leaking that bad!
Keyboard warrior your self wanker.
Edited by abu
i was running 1.3 bar thru the stock bov you f**kin wanker... both atmo and plumbed back and either way it fkn leaked. dont try and tell me whats right and what wrong i KNOW what it does and i KNOW how it works im stating what it was doing and ill stand by it. dont need someone like u to tell me otherwise lol
What Abu said is correct, I done some research and have spoken to a few people at Chaser Motorworks - the way a R33's BOV works is based on a setup that the BOV is plumbed back into the intake pipe as the engine expect this - without this setup (e.g. atmospheric blowoff) then this will muck up all mixtures and settings hence stalling...
I have to say, I love the Pphsshhttt sound, but if it means non-stop stalling, I'd rather not have the sound so that my car rounds smoothly... but I agree... the stock BOV works perfectly and does its job - don't fix what aint broke... I mean, I'd love to have the ppsshhhttt sound if it's full plumb back but don't know if there's such a BOV that works this way....
Guess getting both the sound and preventing stalling is impossible
Thanks fellas...
Also, what's the difference between a Stock R33 BOV and the following?
Which would host boost better?
Which would make better sound and would both be as good?
Cheers,
http://cgi.ebay.com.au/SKYLINE-R32-R33-R34...1QQcmdZViewItem
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
