  • Replies 149
stock bov forever!
after an expensive lesson (thankyou so much officer - fag) with my atmo bov. the sound sure is nice but aint worth the fine for having one. you drive a skyline. people do not need to hear you because they will always see you a mile away :P its like they have a spider sense for skylines!
I'll bite...short answer...they have larger flow paths and are less likely to leak...they are also interchangeable but you need a larger plumback pipe...
But if you had searched you would have found your answer...
Why are GTR BOV's less likely to leak?
Larger flow path is good for big boost i guess. Anyone know at what power/boost it's good to bin the gtst BOV for a GTR one?
Oh yeah i did search dude. It brought me here :whistling:
Edited by R338OY
Hey fellas,
As most of us know, R33's stall as hell when there's a atmospheric installed - it plays with the airflow meter, mixtures and ecu settings etc which caused really bad stalling issues... I've put back my stock BOV, but I miss the nice pod-suction sound heaps and also the Sshhhhttt sound - driving a turbo without this sound really is a bit of a let-down.
I've heard though, if I get a BOV which has 2 sides - one that plumbs back and the other that vents out - I'll still satisfy the requirements of the car and will also get the nice blow-off sound.
Which ones would do the above - any suggestions, fellas?
Thanks in advance.
just get a good air filter and youll get all the noise. ive got stock BOV with just blitz air filter and i get plenti of noise check my video if u want 2 see
http://www.youtube.com/watch?v=FNF7RUptbFw
Yep I noticed that too when I installed my Power FC
Must be something to do with the tune - I'm all for the standard BOV but am using a SSQ at the moment for other reasons but will be going back to a standard BOV soon
I get no stalling or backfiring at all with the SSQ and Power FC
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
