hey feller's, ive had my skyline for bout 2 weeks, and i have noticed just recently in the last couple of days that the heater isnt working.
i have to put it up to 32, and only minimal heat is coming out...and also when i change the mode ect..i can hear a ticking noise coming from under the dash behind the heater, i bang it a couple of times and it goes away?
just wondering if anyone has had this problem and how do i fix it?
cheers
https://www.sau.com.au/forums/topic/197757-heater/
cheers
That ticking noise is most likely to be your gears (the ones to change direction of heat) slipping.
For the heater, has your car lost any fluids recently?
Edit: To fix the clicking noise, you'll have to take out the dash and replace the gears. You'll be looking at over half a days work taking out the dash then another half to put it back together.
Edited by adam-__-
https://www.sau.com.au/forums/topic/197757-heater/#findComment-3534819
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
