a new radiator will always be a good step, but u need to have the rest of the system fully cleaned and flushed to work properly.
Do u have the heater core system hooked up and flushed...have u had the motor power flushed, have u had the clutch fan (the clutch) replaced, new radiator cap etc?
All of these things when serviced and running properly will give u the best cooling for your car, rather than replacing 1 item. Even ppl who have swapped out the fans for themos wonder why they get poor performace form cooling when their std system was running so poorly to start.
U cant go wrong with the std cooling system for the best performance, but it has to be looked after.
https://www.sau.com.au/forums/topic/197793-new-radiator/#findComment-3534989
So what do i need then? Can i do the flushing myself or should i get a radiator place to do it? Ive been looking for a guide on flushing the cooling system but ive not found one.
https://www.sau.com.au/forums/topic/197793-new-radiator/#findComment-3535031
a rad place can do a power flush where they force the crap out. They can also tell u how clogged the system is, and even do a leak test afterwards to ensure u wont be losing any coolant.
Or u can do it yourself, but it will be fiddly. One method for the heater core is to connect up the hose to the firewall hoses and flush the heater core out. Then u can see how blocked it is in there by the flow coming out. The engine u can just run one of the coolant cleanout bottles through it for a week or so, then dump and replace with coolant. The rad u can take it out the car and just reverse flush that...replace the thermostat with a std nissan item, and new rad cap. Bleed system and yer away...
Id just ask the rad shop if it was me though for piece of mind.
https://www.sau.com.au/forums/topic/197793-new-radiator/#findComment-3535196
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
