Hey guys,
Recently, I was just pulling up at my mates house when a cloud of white smoke. First i thought head gasket right...... lots of white smoke but my idle is fine and she revs fine so i put it down to maybe water after the storm. Next few days driving to work intermittently clouds of white smoke. I thought maybe it was a overly restrictive breather system that i installed but its fine i think. I have ex and in connected to each other then to catch can and catch can to intercooler piling. blocked PVC
So far i have these opitions:
1. small leak in the head gasket which means i should start to get lumpy idle, oil in coolant and in stuff under the oil cap.
2. Its a valve stem which i have no idea to diagnosis or what the F it is
3. turbo seal... therewas some white smoke coming from the dump
oil or water?
helpplease :dry:
1. Small leak in headgasket is one of the most likely the cause. It could be a leak from the coolant gallery to the combustion chamber only, which would allow coolant to burn (white smoke)
U wont get oil in the coolant always from a blown hg.
2. Valve stem seals allow oil to drip into the chamber and would burn off blue smoke. Only usually in the mornings when the oil has had a chance to drip down. No chance.
3. Could be a turbo seal. Same deal, coolant being burnt (white smoke.)
radiator places can do a test on the coolant to check for exhaust gas in it (forgot the name) Id advise to stop driving the car, or take it easy until u can get it tested.
Edited by Bl4cK32
IF it helps... i had oil on the bonnet and in the engine dip stick blown out! blow by (i think it is called) I had the same catch can setup with only diff now being the adapters which are quire restrictive. the PVC is blocked. in and ex linked and than to catch can > to intercooler. and i raised boost recently! can revs feel in neutral
Can you retype that, as i can't understand what you have written?
From what i have made out: You can not have your catch can feed into your intercooler piping, as you'll be pressurizing the system. The "venting hose", coming out your catch can, should vent into the turbo intake pipe (the pipe between your filter and turbo) or vent into atmo (illegal, but commonly done).
What do you mean by saying "PVC is blocked off"?
Some good pics would also help us determine whether your catch can is installed incorrectly. I have seen people attempt to install these themselves and do it wrong. If you pressurize the "system", you'll be forcing oil through the piston rings, seals, etc., thus causing oil to be burnt (hence the white smoke) and possibly causing damage to the engine.
The catch can setup involved the following: 1. intake cover and exhaust cover linked 2. the connection between the intake cover and the pcv valve on the intake manifold has been blocked 3. the linked exhaust and intake covers are feed to a catch can 4. the catch can is plump back into the intake piling between the air pod and turbo
is this correct?
I think if you block the PCV you need to vent to atmo, not feed it back into the intake pipe.
Mine is setup as follows:
PCV blocked. IN & EX cam covers linked, then to catch can, vent to atmo.
Well,
i performed a dry compression test today on all 6 cylinders with WOT and warm engine. All came back with 130 psi across the board. I checked the oil cap and there is no excess air and the oil seems to be the right viscosity. Radiator doesn't buddle or have oil in it. The exhaust doesn't imediately give out white smoke the warmer the more the smoke i get.
Any ideas anyone?
awesome........ could it be a restrictive breather on teh catch can creating increased crankpressure
easy to eliminate, remove hoses from breathers - if it still happens then you've at least ruled that out but i doubt thats your problem. i would perform leak down also
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
