Oils - Engine, Gearbox, Which Ones And Where To Get?
Hi all,
Went down to autobahn today to pick up some Redline shockproof, but it seems they don't sell it anymore.
Where can I get some in Adelaide? Northern suburbs preferred if possible.
Cheers.
Edited by Ionos
  • Replies 59
dont use redline in your gear box its not good for jap gear boxs ask michael at auto barn mile end and mark tillbrook as the components in the oil isnt good and can cause alot of damage!!
Well, all reports I've heard are that it can work wonders on a worn gearbox. I've got a bad crunch going into 5th gear. I also used it in my last skylines with no dramas, but open to hearing alternatives short of a gearbox recondition.
Hey Kel, nice to meet you the other night...........do you know what these guys recommend for a GTR engine and driveline and if so, any chance of putting bit of a list together, I should be dropping all the oils cos who knows when they were done....I've only had the car for 4 weeks.
Hey guys, I know you probably already have your favourite brands of engine oils (generally Synthetic) but has anyone considered ULX-110 which has all the advantages of Synthetic without losing the advantages of Mineral based oils. A guy that I worked with at Adelaide Engine Service for many years is the National Distributor for the oil which is now used by many Top Fuelers around the world including my mate Marco Elbe who runs a 6 sec Keith Black '57 Chev that you may have seen at the Extreme Horsepower Show...if you knew what Marco has spent on that engine you know he wouldn't use a mineral based oil unless it was fully tested and proven.....here's an extract from their website;
http://www.ulx110.com/
Performance Advantages: Our multi-grade oils for gas and special fuels such as top fuel and alcohol have been designed with the help of some of the top engine builders in the United States. Demulsifiers and anti-scuff agents have been added for extended protection. Dyno tests have consistently shown an increase in horsepower consistent with synthetic oils but with none of the bad side effects such as scuffed cylinders and piston skirts, detonation, and weak spark due to wet plugs. Better oil pressure during severe and continuous service applications along with a reduction in oil temperature of 20F or more is also a plus. Our 2 friction modifiers work together to coat internal engine parts which results in protection at start up, and reduction of internal friction by 38%. This results in reduced fuel consumption of 8% or more in most vehicles.
Like I said, I'm good mates with the National Distributor and would be happy to approach him for a group buy if the interest was there....ULX-110 may even help the well known problem with RB engines where too much oil hangs around upstairs causing alot of blow-by.
i have redline in my 31, running 25 box, has made the box feel alot better since going to it, been in there for a few months now, cops a thrashing once a month and no dramas yet.
I have also heard this theory too of it being bad but thought i would try for myself and my mechanics said it is a good oil and the amount of hours they have put into that car i doubt they would wanna put anything bad in it.
Oh and where to get it - fours n more can get the stuff in, would probly be cheaper through motor traders though.
Edited by skylineguy19
Hi gang,
Changed the thread topic since I got my answer, and some good discussion going on.
RB25DET gearbox takes 2.8L - more will go in but will cause problems. Some people fill it to the brim, that is not correct! You wouldn't fill your engine with oil to the brim would you?
http://www.skylinesaustralia.com/forums/Ch...+oil&st=20#
Cheers.
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
