Hey guys/girls,
This my be a stupid qustion but can i potentially do any damage to my car if I drive with the silencer in the exhaust?
The car is tuned at 381rwhp @ 18psi and I'm running a Blitz Nur SpecR exhaust which is pretty loud.
Running poncams also which makes it a bit lumpy and even louder again - pretty much instant yellow sticker job if I pull up next to a cop car.
So although it drives like an excel with the silencer in, if I am just putting around not driving at all fast can anything go wrong?
Obviously i would take it out when wanting to drive it hard, but I'm just concerned I might damage something by restricting the flow so much.
Cheers,
Tay
Edited by taynewguy
https://www.sau.com.au/forums/topic/197836-driving-with-silencer-in-exhaust/
I remeber a magazine article were they were testing a high flow cat, car had been tuned for the high flow cat, so they decided to see the diff the original cat made.
Stock cat ended up being a massive restriction causing detonation etc(high rpm end). so I see your new silencer as causing similar effects IMHO.
Ok cool, thanks for the heads up guys. I just put it on yesterday to see how much it would quieten it down and went for a sunday drive.
Didn't really give it a hard time but didn't see any excessive knocking either way.
Found out pretty quickly that it's no fun, deadly slow and with absolutely no accelleration.
Anyway, that drive didn't last long. Quickly went home ripped it off and went for a real blast up in the hills.
All smiles again :banana:
Edited by taynewguy
I got one of those.. keep it in the boot actually, it's got me off a yellow sticker before for my exhaust being too loud :laugh: I just said it'd loosened and come out and I needed a screwdriver to get it back in ;)
Driving with it thou is boring, and sounds like crap!!
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
