No really cable ties...
Don't front bars screw on, and don't side skirts screw on and don't rear bars screw on, yeah sure there are some clips as well... but I've had all of my kit off and its all screwed no from factory
manufacturers use double sided tape in places...
Edited by 75coupe
Yeah was just wondering all the facts before i start pulling everything off knowing me i always do it the hard way ...haha
if its a brand new kit then fitting isn't as easy as just putting it on and screwing it on. ALL fiberglass bodykits need some sort of modification to fit and its not easy to get right, make sure u do the right research before you get into it, if its a plastic kit your all sweet just screw and clip it back on, will have holes and everything where its ment to go
Yeah i got the side skirts on today wasnt to hard some parts dont really fit very well but dosnt look to bad considering its not painted i gota find some sort of double sided tape to stick down the door jam area .... starting the rear bar 2moro
i dont think double sided tape will hold use ureathane,screws or pop revets
About putting kits on. Got mine put one but don't have bumper indicator lights. Now none of my front indicator lights are working and they rear ones that are are flashing reallly really fast. What am I supposed to do now? Anyone know how to fix it?
Hey fellas got it on the other day its just sitn on bye a couple cable ties and nuts and bolts lol dudes im start to hate it though i cant even get out the damm drive way now its sucks ass please dont mind the low pics takn with my ph but really its not that hard to put on but make sure you gota enough bog to fix up your mistakes lol
Edited by Mobies
Ummm... the auto electrician took a look at my car and he claims that he can't see any indicator lights where the headlights are. Could someone point out where on earth the indicator lights are located?
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
