As some of you have no doubt seen.
As much as it pains me, the time has come for me to part with my R. It is rarely used and I have a garage full and driveway full of toys so its time to rationalise.
*** Located Perth ***
*** Will now look at trades on R34 vspec ***
Brief details:
BNR001541 - 1989
Car delivered in 2004 (as a silver car) undamaged with history and 89k's.
I have original condition pics for those who want them.
I also have the original log books and service sheet data ranging from general service to spring specification and suspension counterweighting information and aftermarket parts manuals (EVC, exhaust, stereo etc).
Rarely used:
approx 11,000k's in the past 2 years.
Always garaged and covered.
Exterior:
no expense spared bare metal repaint in silver candy.
lots of new parts,
front bar lip,
rubbers,
seals,
N1 headlights.
Wheels:
option of std wheels or pictured.
Engine Bay and underbody:
detailed and repainted in original light grey colour (sorry if the pics make it look white),
new decals,
new front undertray,
new front guard liners,
underbody resealed.
Interior:
full professional retrim in micro-suede in original colours,
nismo 260k speedo - showing 11,000k's,
new centre console surround,
new dash surround,
new genuine gearknob,
skyline mats,
new leather gaiters for gear and handbrake,
sony cd-mp3 player.
Mods:
Tokico sus,
apexi N1 exhaust,
stainless front pipes,
relocated oil filter kit,
air filter kit,
oil cooler kit,
trust icooler,
HKS EVC,
nismo struts braces,
earth kit,
Tomei hicas cancel,
piping kit,
jap tuned ROM,
greddy oil pressure gauge on pillar,
Greddy radiator air flow diversion plate.
Recent maintenance:
new tailshaft,
overhauled brakes,
rear diff removed - new seal kit and fluid,
engine oil done every 3,000k's.
Have std piping and std airbox to go with it.
I am open to serious offers around 30K
Interstate transport can be arranged.
Sorry, no joy riders.
zilla,
0411 600 883
Edited by R32zilla
https://www.sau.com.au/forums/topic/197973-r32-gtr/
interior pics & outside right/rear shots pls
is it running stock turbo's? do u have any dyno numbers?
are you running 18inch wheels?
there is no mention of year model so pls specify
Edited by Marko R1
https://www.sau.com.au/forums/topic/197973-r32-gtr/#findComment-3538344
When I saw this car the condition of it blew me away
Amazing attention to detail that's for sure.
Nigel , I'll swap my '94 and my first grandchild :D
sold!!!
thanks for the kind words!
https://www.sau.com.au/forums/topic/197973-r32-gtr/#findComment-3541407
  • 4 months later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
