Hey, i have a 1990 R32 GTR.. And i have just a few problems that i was woundering if anyone mite have a clue what it might be.
Firstly My All wheel drive system.. The fuse is in the fuse box, and has been replaced. The light does not come on and im running or rear wheel drive all the time.. its not a major problem but just would like to have all wheel drive.
Secondly. some times while driving normaly and more so when giving it some it runs real ruff idles low etc. the way i fix this is to turn the key off and turn it back on again while still moving and it goes away? I have a power FC, split fire coil packs, ridum plugs, 3inch exhaust, pods,.. i have checked all wiring and earth points and even reset the computer and retuned it..
some one please help,
https://www.sau.com.au/forums/topic/197992-gtr-cutting-out/
^^^ This forces rear wheel only mode.
Id take it to someone who knows GTRs, as there sounds like a problem with ATTESA (or ABS, as they share sensors).
If I had to put money/take a guess on the problem Id say your ATTESA pump is shagged.
https://www.sau.com.au/forums/topic/197992-gtr-cutting-out/#findComment-3537897
ive pulled the fuse to the atessa and it still has that cutting out problem.. there are not to many people up here that know GTRs Maybe its my air flow meters.
Are maybe your rite about my etessa pump being shagged..
thats heaps for your help mate.
https://www.sau.com.au/forums/topic/197992-gtr-cutting-out/#findComment-3538847
regards the running rough and bad idle.
check the usual suspects.
Spark plugs (buy a set of NGK copper plugs with heat range of 6 and a gap of 0.8mm) - $4 each
Check and clean your AFM's (may possibly need re-soldering - search this forum for AFM+SOLDER to find details)
AAC valve - clean it - instructions are available in the DIY section.
all of the above will simply take time and very little dollars compared to what you've already spent on re-tuning and so forth.
https://www.sau.com.au/forums/topic/197992-gtr-cutting-out/#findComment-3539002
  • 3 weeks later...
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
