Wondering if anyone has cracked the OBD2 consult 2 side of the V35 yet in regard to using a P.C and Interface plugged into the consult port under the dash and can offer advice.
I have scanners that I used on other cars and interfaces but not sure how to go about accessing the internals of the V35. Consult 2 is too expensive for me.
Following on from that what can you access, what does it mean and what can you change?
Gibbo
https://www.sau.com.au/forums/topic/198016-scantools/
Gibbo
I have. The OBDII protocol is no bigge it's just a standard protocol but you can't do much with it. I'm currently working on Nissan Data Scan II that will work with Consult II protocol. So far I can monitor most parameters and registers. The final product will also let you log data, adjust idle speed and ignition timing as well as reading and clearing error codes. The NDS II software and PC adaptor will be available through Blazt.biz.
Cheers,
Tom
https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3537961
I have the Autoenginuity Scantool and it is very limited with the V35 as JDM cars do not run the OBD-II interface, they use a different protocol, not even Nissan's Nissan Consult at a service department could talk to the car.
https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3539974
Consult_Protocol___Commands_Issue_6.pdfWill see as tomorrow it goes in to the local dealership. I think the issue is more the Nissan proprietry code or extensions that it uses.
The G35 guys say consult 2 works and I see no reason why it would not. I think the skill level of the Nissan Technicain comes into play here not so much the tool.
This is the Consult Protocol attached.
https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3539999
Yeah, thats the Consult I protocol from PLMS website prepared by Nissan Technical Group. Completely different to Consult II protocol and can't be used on our v35 Skylines.
The Consult II unit from Nissan dealership will work but do you want to spend $2500 to get one?
Tom
https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3540790
  • 6 months later...
http://www.nissantechmate.com/detail.aspx?id=513
need someone in the USA to get it though. they will not ship outside the USA and if you email them you will end up with a call from repco here in Oz. the machine that repco offer does not work on a 2001-2004 v35 but does on a 2004.5 up.
look at the launch x413 if you want to play with the internals of that car. as for software packages - no real idea - I use scanners.
https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3962499
    • Not bad, thanks for sharing. I bought some black nismo floor mats, hopefully thats enough, im not a fan of the 90's jdm light grey!
    • You forgot just needs a battery and no test drive until full payment is made. 😆
    • I might end up in that category if I can't get mine started soon.... I know wati got! no low ballers, also no test drives (due to no starting). Ran when I parked it 5 years ago. Period correct mods include some shit wheels I bought for 400  bucks 15 years ago. Only been crashes 3 times
    • For both insurers I took floor plans and detailed photos showing the location from the street. They agreed that it was not visible from the street (nothing is, it's a completely opaque solid fence controlled by electric gates that people CONSTANTLY state they cannot access to deliver shit). There's basically a garage door or solid wall around the entire property line. They even agreed that if I put another roller door in they would consider it, in the same sentence agreeing it wouldn't make it more secure. Prior to this I had Shannons at my previous address - Their policy was over double what Famous were at the time. I'm a guy in my 40's with no licence suspensions (no demerits at all) and no claims. They just don't wanna know about it/don't want the business.
    • True, but they can be flexible.  I was at a property for a couple of years without a garage and we worked around it by parking the car in the backyard under a car cover. The car was not visible from the front of the property. I don't know if you can work some magic like this at your current place? I only have great things to say about Shannons.
