wabbo69 Posted December 17, 2007 Share Posted December 17, 2007 Wondering if anyone has cracked the OBD2 consult 2 side of the V35 yet in regard to using a P.C and Interface plugged into the consult port under the dash and can offer advice. I have scanners that I used on other cars and interfaces but not sure how to go about accessing the internals of the V35. Consult 2 is too expensive for me. Following on from that what can you access, what does it mean and what can you change? Gibbo Link to comment https://www.sau.com.au/forums/topic/198016-scantools/ Share on other sites More sharing options...
TomR33 Posted December 17, 2007 Share Posted December 17, 2007 Wondering if anyone has cracked the OBD2 consult 2 side of the V35 yet in regard to using a P.C and Interface plugged into the consult port under the dash and can offer advice.I have scanners that I used on other cars and interfaces but not sure how to go about accessing the internals of the V35. Consult 2 is too expensive for me. Following on from that what can you access, what does it mean and what can you change? Gibbo I have. The OBDII protocol is no bigge it's just a standard protocol but you can't do much with it. I'm currently working on Nissan Data Scan II that will work with Consult II protocol. So far I can monitor most parameters and registers. The final product will also let you log data, adjust idle speed and ignition timing as well as reading and clearing error codes. The NDS II software and PC adaptor will be available through Blazt.biz. Cheers, Tom Link to comment https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3537961 Share on other sites More sharing options...
wabbo69 Posted December 17, 2007 Author Share Posted December 17, 2007 Cool and thanks. I might hold off buying the Autoenginuity Scantool with Nissan extensions as that seems the best I can find. Link to comment https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3538011 Share on other sites More sharing options...
NA_R33 Posted December 18, 2007 Share Posted December 18, 2007 I have the Autoenginuity Scantool and it is very limited with the V35 as JDM cars do not run the OBD-II interface, they use a different protocol, not even Nissan's Nissan Consult at a service department could talk to the car. Link to comment https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3539974 Share on other sites More sharing options...
wabbo69 Posted December 18, 2007 Author Share Posted December 18, 2007 Consult_Protocol___Commands_Issue_6.pdfWill see as tomorrow it goes in to the local dealership. I think the issue is more the Nissan proprietry code or extensions that it uses. The G35 guys say consult 2 works and I see no reason why it would not. I think the skill level of the Nissan Technicain comes into play here not so much the tool. This is the Consult Protocol attached. Link to comment https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3539999 Share on other sites More sharing options...
TomR33 Posted December 18, 2007 Share Posted December 18, 2007 Yeah, thats the Consult I protocol from PLMS website prepared by Nissan Technical Group. Completely different to Consult II protocol and can't be used on our v35 Skylines. The Consult II unit from Nissan dealership will work but do you want to spend $2500 to get one? Tom Link to comment https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3540790 Share on other sites More sharing options...
wabbo69 Posted December 19, 2007 Author Share Posted December 19, 2007 Thanks Tom, Anyone got consult 2 details or can refer to appropriate site with details of it? Where can you get Consult 2 for $2500? Gibbo Link to comment https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3541219 Share on other sites More sharing options...
TomR33 Posted December 19, 2007 Share Posted December 19, 2007 Try www.obdfactory.com, they used to have some. or eBay Link to comment https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3542994 Share on other sites More sharing options...
rs73 Posted June 22, 2008 Share Posted June 22, 2008 Also i came across this: http://www.uprev.com/products/cipher_NI.html $400 for software and cable. just use your own laptop, but doesn't support palm pc/windows mobile. Link to comment https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3962187 Share on other sites More sharing options...
Chris Rogers Posted June 22, 2008 Share Posted June 22, 2008 http://www.nissantechmate.com/detail.aspx?id=513 need someone in the USA to get it though. they will not ship outside the USA and if you email them you will end up with a call from repco here in Oz. the machine that repco offer does not work on a 2001-2004 v35 but does on a 2004.5 up. look at the launch x413 if you want to play with the internals of that car. as for software packages - no real idea - I use scanners. Link to comment https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3962499 Share on other sites More sharing options...
wabbo69 Posted June 22, 2008 Author Share Posted June 22, 2008 Chris, How much does it cost.I migh...might be able to get someone in the us to on forward it for us. Link to comment https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3963581 Share on other sites More sharing options...
Chris Rogers Posted June 23, 2008 Share Posted June 23, 2008 $3500 with USDM software. Link to comment https://www.sau.com.au/forums/topic/198016-scantools/#findComment-3964213 Share on other sites More sharing options...
