Item: XHP Saber 18x8" Chrome with Falken Ziex 235/40R18
Age: N/A
Condition: Wheels: excellent condition, refer pictures posted 3/1/07. Tyres: Refer pictures posted 3/1/07.
Price: $1200. Price drop to $800
To Fit: 5x114.3 stud pattern
Contact: Aaron - PM or SMS/Call 0416495282
Comments: Unsure of offset yet but fits R33 GTS-T nicely.
XHP Wheels
Edited by aaron_25t
https://www.sau.com.au/forums/topic/198022-18-chrome-wheels-with-tyres-800/
Age: N/A
Condition: Wheels: excellent condition, no gutter rash or flaking. Tyres: 70-80%
Price: $1200
XHP Wheels
You got a side on pic of the car with em on there?
Mine is pretty similar to your ride. I'm just worried about traction with 235. I'd be all over the shop .lol.
Yep I'll post one up tonight.
Cheers - nothing, just the lighting/reflection :banana:
Spunky Munky - we spoke the other day and you followed up with a text too? Thought it was sorted so I figured no need to reply?
nice rims, wtf happened to the bonnet?
Yeah mate, sorted - I'll contact you soon to tee up the collection.
Cheers.
Got the wheels back yesterday. I've never damaged the wheels before, but on closer inspection I did notice a few things:
1. Minor scratches, I didn't even know these were there and had to put some effort in to get them to show in the photos.
2. There is a chunk of rubber missing from one of the the tyres, doesn't look too good but the tyre is fine.
Also attached a pic of two of the tyres (other two are in similar condition) - the rear ones have some wear due to bad alignment I'm guessing.
Spunky Munky - I'll put these back on the market for now. If you are still keen - PM me.
Cheers.
Edited by aaron_25t
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
