Does anyone have an idea why my A/C would blow hot air after i give the car a bootfull.
Car is a 33 gtst sedan, works fine when your driving sedately, but if you start doing some harsh acceleration it just blows really hot air. the car has too cool down before it'll go back to being normal A/C again.
Would it be a sensor gone? I've done the system test and verything seems fine by the numbers.
cheers
https://www.sau.com.au/forums/topic/198030-another-air-conditioning-problem/
The ECU controls the operation of the AC compressor. The ECU will turn the compressor off when accelerating hard to remove load from the engine when you really need it.
Cheers
cheers
But after I've calmed down from my lead foot, I have to wait till car cools down and I have to hold the off button down (reset?) before it starts to work again. Usually the next morning.
It also blows the hotness if i've switched off the A/C
It sounds like the ECU is not switching the compressor on after hard acceleration. To check you will need to monitor the voltage at pin 9 (AC cut signal) before and after you load the motor. With the AC off you should have approx battery voltage at pin 9. When the AC button is pressed the voltage should drop to 0-1V.
Likewise pin 46 (AC switch signal) should have approx battery voltage when the AC is off and approx 0 volts when the AC is pressed.
Hope this helps.
Cheers
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
