Hey guys,
I'm new to the forums and all this nissan thing! I'm looking into buying a R33 Series 2 very soon as i've just sold my car!
Now as i said above, i don't know what to look for when buying a skyline, good service history, mild mods ? If someone can break them down in a list that would be very helpful!
Oh and I'm in SA!
cheers
vlad
https://www.sau.com.au/forums/topic/198101-buying-a-r33-gt-t-s2/
Hi Vlad, Personally i would be buying one with some tasteful mods, such as Exhaust, Front Mount Cooler, Power Fc. Now they are the basic mods you NEED to be able to get decent power, but then comes turbo, fuel pump, air flow metre which are more of a personal choice, where as the exhaust and so on are a must and generally cost a bit more(apart from a new turbo), When it comes to bodykit and wheels.......... they are a personal choice and no doubt you will change them up when you want your own look. Hope that helps
Darren
P.S mines for sale for the right price...... >_<
Darren
Hi Darren,
Thanks for the reply! Honestly i don't want a car with excessive mods, as i am sure i wont use the full potential of that car! So as you have said I'd be looking into a car with really simple mods, exhaust, front mount etc. Your car does look nice but from the pictures I'm sure it will be out of my price range :)
Vlad
believe me mate once you put your pedal to the metal and feel that rush....you will be making use of all the power you got....as my advice get something stockish if you can and also make sure its manual...autos in skylines just suck man
I think he's talking about a 2 way, then it's most prob been drifted/thrashed
nah, an a-lsd acts like a very lazy viscous, locks when it wants, single spins around corners etc....
there in the v spec gtr's and late late model r33 gtst, im gettin rid of mine....
when u buy ur s2 look above the rev taco, if it has slip light and a-lsd the car has it
cheers, oh...and ur car wnt stay stock lol u will mod it when u feel the potential
what ever have you driven a auto skyline with a stage 2 shift kit etc pfffft :rofl:
^ but, but, the interwebz sez i'll be faster in a manual! LOL
Personal opinion, and purpose must be considered. For circuit work and hills, I still believe manual would be better. If cruising and drags is your thing, then shift kitted auto hands down.
^^ sorry I have to disagree with you Lee, and totally agree with Allan.
I haven't yet done the kevlar plates/belts, upgraded stall converter and valve body to my R34 yet, but even with the standard auto trans I would kick the living snot out of a same power R34 anywhere - including the hills. With my steering wheel controls in semi-manual mode, I can change gears and apply power significantly earlier than a manual could - hence take higher speed into the corner (change down to slow myself down with my foot still on the throttle), then change up past the apex with my foot planted to the floor. I would be gone and have 2 gear changes done in the time a manual could match revs, clutch safely and apply power safely without spinning the wheels.
And once I get my trans upgrade done I am assured it will be 100% better, faster and stronger. I can't wait - and it will cost a lot less than my twin plate Exedy cost me in the S15 :rofl:
Yep love the clutch kicks man....and as per above comment i think i was applying what i knew from personal experience....and i disagree with hills driving even if yours is semi auto....maunals will any day give the driver a lot more better control then auto shiftkits or tiptronic...
yeah true, it all comes down to personal preference. I was just disagreeing with
- and yes, I realise it says lol :D
But I say don't make statements unless you have been through the hills in a tiptronic - it just makes you come off as ignorant. :O - like I said, (once I get my shift kit & trans upgrade) I guarantee you I will kick any manuals ass with the same power through the hills :rofl:
^Ahh, I see why you said what you did andrew, but I was actually trying to take the piss that so many young people "read something on the internet it must be true!"
I actually think that tiptronic auto's are the way to go, and would love to have a Golf GTi with the DSG gearbox, or even (just) the tiptronic Liberty GT would be nice!
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
