Hey guys,
I'm new to the forums and all this nissan thing! I'm looking into buying a R33 Series 2 very soon as i've just sold my car!
Now as i said above, i don't know what to look for when buying a skyline, good service history, mild mods ? If someone can break them down in a list that would be very helpful!
Oh and I'm in SA!
cheers
vlad
https://www.sau.com.au/forums/topic/198101-buying-a-r33-gt-t-s2/
Hi Vlad, Personally i would be buying one with some tasteful mods, such as Exhaust, Front Mount Cooler, Power Fc. Now they are the basic mods you NEED to be able to get decent power, but then comes turbo, fuel pump, air flow metre which are more of a personal choice, where as the exhaust and so on are a must and generally cost a bit more(apart from a new turbo), When it comes to bodykit and wheels.......... they are a personal choice and no doubt you will change them up when you want your own look. Hope that helps
Darren
P.S mines for sale for the right price...... >_<
Darren
Hi Darren,
Thanks for the reply! Honestly i don't want a car with excessive mods, as i am sure i wont use the full potential of that car! So as you have said I'd be looking into a car with really simple mods, exhaust, front mount etc. Your car does look nice but from the pictures I'm sure it will be out of my price range :)
Vlad
believe me mate once you put your pedal to the metal and feel that rush....you will be making use of all the power you got....as my advice get something stockish if you can and also make sure its manual...autos in skylines just suck man
I think he's talking about a 2 way, then it's most prob been drifted/thrashed
nah, an a-lsd acts like a very lazy viscous, locks when it wants, single spins around corners etc....
there in the v spec gtr's and late late model r33 gtst, im gettin rid of mine....
when u buy ur s2 look above the rev taco, if it has slip light and a-lsd the car has it
cheers, oh...and ur car wnt stay stock lol u will mod it when u feel the potential
what ever have you driven a auto skyline with a stage 2 shift kit etc pfffft :rofl:
^ but, but, the interwebz sez i'll be faster in a manual! LOL
Personal opinion, and purpose must be considered. For circuit work and hills, I still believe manual would be better. If cruising and drags is your thing, then shift kitted auto hands down.
^^ sorry I have to disagree with you Lee, and totally agree with Allan.
I haven't yet done the kevlar plates/belts, upgraded stall converter and valve body to my R34 yet, but even with the standard auto trans I would kick the living snot out of a same power R34 anywhere - including the hills. With my steering wheel controls in semi-manual mode, I can change gears and apply power significantly earlier than a manual could - hence take higher speed into the corner (change down to slow myself down with my foot still on the throttle), then change up past the apex with my foot planted to the floor. I would be gone and have 2 gear changes done in the time a manual could match revs, clutch safely and apply power safely without spinning the wheels.
And once I get my trans upgrade done I am assured it will be 100% better, faster and stronger. I can't wait - and it will cost a lot less than my twin plate Exedy cost me in the S15 :rofl:
Yep love the clutch kicks man....and as per above comment i think i was applying what i knew from personal experience....and i disagree with hills driving even if yours is semi auto....maunals will any day give the driver a lot more better control then auto shiftkits or tiptronic...
yeah true, it all comes down to personal preference. I was just disagreeing with
- and yes, I realise it says lol :D
But I say don't make statements unless you have been through the hills in a tiptronic - it just makes you come off as ignorant. :O - like I said, (once I get my shift kit & trans upgrade) I guarantee you I will kick any manuals ass with the same power through the hills :rofl:
^Ahh, I see why you said what you did andrew, but I was actually trying to take the piss that so many young people "read something on the internet it must be true!"
I actually think that tiptronic auto's are the way to go, and would love to have a Golf GTi with the DSG gearbox, or even (just) the tiptronic Liberty GT would be nice!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
