Guest RedLineGTR
GoFastBits Hybrid B.O.V All In Silver Colour, With Flange To Fit a R33 gtst, just remove stock bov and fit this one. In Perfect Conditon, also have receipt.
Includes:
1x GFB Bov
1x Flange Adapter For R33 gtst (Assume will fit one Some others)
1x Vacuum Hose
1x Weld on Adapter (Comes with bov if not needing flange)
1x Custom Plumb Back Hose (From Bov to stock pipe)
*Have Original Receipt As Well*
PM OR EMAIL ME (LOOKING FOR MELBOURNE BUYERS)
The HYBRID Atmosphere and Plumback totally eliminates backfiring on air-flow metered cars, but will still give the great sound you want. It has a larger venting capacity than the Mach 1, and in addition to the single trumpet it also has a plumback outlet which is connected to the Factory Valve's return line. Designed for all turbo vehicles, including BIG BOOST applications.
Specs
Venting: Twin staged outlets, 1 plumb back nozzle and 1 atmosphere trumpet.
Inlet area: 506 mm2
Outlet area: 400 mm2
Flow capacity: 80.1 cfm (at 20.5 inches of water).
Piston seal/cushioning: Yes, tapered acetal.
Quad-ring piston seal: Yes.
Total length: 125 mm
Materials: 6262-T6 aluminium except the piston (brass) and seat (acetal).
Fitting method: Fits 35 mm I.D. rubber hose or 1" O.D. steel/alloy pipe. A short length of 1" pipe is included in the kit for weld on applications. Standard plumb back outlet fits 30 mm I.D. hose.
Spring adjustment: Yes, via the vacuum nipple.
Maximus boost: Factory tested to 110 psi.
https://www.sau.com.au/forums/topic/19813-gfb-hybrid-bov-kit/
  • 1 month later...
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
