  • Replies 86
get off your arse and ask them already. this thread has been going on 4 weeks now and still no action. I would suggest that if you are under 35 then it will take some serious convincing to make it happen. but just use your balls and ask. they are not going to punch you out. the worst they can do is say "f**k off".
Well very funny you say that Beer Baron! I have been away for the new year etc etc... and am quite lazy
I had a discussion with the lovely gentleman from Audi... He actually didn't really seem to pick me as a tyre kicker or anything he was more than happy to help out...
However, just to really put a dampener on things the guy said that the only test vehicle anywhere near Australia is in NZ at the moment!!! Which makes it kind of hard to get to from Vic :O
Farrrrk!!!!!
I did manage to get a full tour of a left hand drive one though!!! Absolutely wicked car everything is just right (Was the clutchless manual:( though much prefer the real deal)
Bang & Olufsen stereo... who would need one of those with that awesome sounding engine?
Ohh well onto bigger and better things I guess... anyone know where I can find an Enzo ;) (Joke)
Nope, I did get his card though as I dropped the line I might need something for the wife and kids... RS4 anyone?
Oh well nothing ventured nothing gained I guess, totally worth giving it a crack though :P
Thanks for all the input but don't end the thread as I'm finding the ideas very amusing :thumbsup: some awsome ideas for a sunday arvo!!!
I dont know why you want to test drive the R8??? it doesnt even get any more power than the RS4, not to mention the extra cost which is astronomical. The chassis is no doubt nicer, but i can assure you that the RS4 has more than enough ability to have fun anywhere you want. And yes, i have driven an RS4 on a regular basis
*it's 100kg lighter
*it has better weight distribution
*it's a sexy coupe rather than a family-spec 4 door
and it also features
*bigger brakes F&R
*much better interior
*dry sumped engine for lower centre of gravity and absolute piece of mind on track days
*better inlet and exhaust for faster revving
*much more sporting dynamics due to MR design
*aluminium alloy construction
since an NSX cost ~$245K when it was last on sale, does $269K sound unreasonable to you for a car also made from aluminium, but much more modern, with much higher power and more cylinders?
to be honest, the R8 does not appeal to me at all.... I drive an RS4 and could not see me forking out the extra $100k+ for the R8. $259k is for car only. They are closer to $300k once on the road. You could probably bargain them down closer to $280 but its alot more than an RS4....
I do admit, it would probably make an awesome track car, but how often do you honestly see anybody who buys an R8 putting it on a track?
lol i dont even know wat a rs8 is except that its a audi n can be brought with monopoly money lol. some1 chuck up a pic plz thank!
the RS8 should pretty much look the same, but will be powered by a heavily modified version of the 5.2L Audi V10 (might even end up closer to 5.5L)
Yes....
and for the love of god, how the hell do you begine to draw comparision between a RS4 and a R8 ??????
Exactly my thoughts. It's like people comparing the RB26 powered GTR's to the new GTR, they are completely different cars and worlds apart.
    • What a wonderful journey to read. Loved the photography. Literally found this an hour ago and couldn't stop reading, plus checking out a couple of the links. Was interesting as you had a few mods very similar to my sons Gtt, including the sheetmetal homemade V-Spec II rear diffuser, can't be too many of them around the world. Only to find it sold about three weeks ago. Well at least I won't have to keep re-visiting for updates. Anyway, well done on not just the car but the well written story and descriptions, and of course the pics. Good luck on your next one. Rob
    • Forgot to update. I ended up removing it and found out that it's dead. The car seems to run better than it did, although I haven't driven it hard yet. Literally just a flow restriction.
    • Sounds like the rack seals blew.
    • ^ This is all good advice. I can imagine that there's some passive components in the HVAC controller that run that PWM output that could die, or suffer bad solder joints. It can be worth opening it up, taking a schmooze around looking for swollen electro caps, evidence of liquid escape anywhere, tracks that have been hot, lifted, cracked, etc. A DMM might not be suitable for seeing if the PWM output is pulsing. Might be too fast and too low voltage for a DMM to keep up. An analogue voltmeter might give a better hope. I use a handheld oscilloscope (<$100 from Aliexpress if you want something cheap). A DMM might see the voltage across the motor flicker. Otherwise, as above. If you can successfully see PWM action, then the control side should be good. If you can't see it with what you have, you might need to step up the instrumentation used, as above. Beyond that, and dbm7's advice on testing the motor directly, you're down to looking for broken wires, corroded connector pins, etc.
    • So Thanks for the comments etc. To follow up on this, we went down the path of fitting a divider down the middle of the external pipe that was added to the exhaust manifold and the divider went from very close to the external wastegate all the way up to the "V" part where the pipes from each side of the manifold joined. After this modification it was finally in a position to do the dyno-tune with some degree of success. Top end power was down about 10kw (250rwkw down to 240rwkw) I believe from previous but it seems to be more responsive lower down and at least it is now driveable and fun and back on the road to be enjoyed. Apparently the timing couldn't be run the same as it was running into knock and boost was down about 1psi. For all we know this could have been from the fuel being a bit older, or perhaps some slight complication from the new head gasket as we didn't have compression figures from before that mod to compare. I'm no mechanic and this is second hand info but I just wanted to follow-up to those that commented or read the original post with interest. After so many months of stuffing around this is a big win. The interesting part was most of the info around this was gained from information around Barra motors and not GTR as the manifold setup on the Barra with single turbo was more similar.  Thanks for those that helped with info. Regards Rob
