I might be wrong, but I do get infos on Audi plenty early than the general public. I remembering quoting the new RS6 to be a V10biturbo, but I was refute at the time.
Yes you are 100% correct. The new S6 is a V10, the RS6 is a 5.2L V10 twin turbo, with 426kw. Which is a LOT. Now if they put that in an 'R8' that would get it moving.
  • Replies 86
Yeah, but you also have an S4 and an S6, which are fast. Then you have RS4s and RS6s... which are super fast. So logically an RS8 would be the faster version of the S8?
the A8 is an Audi luxo-barge like an S-class Merc- they don't really do ultra hi-po versions of it, so the sportier version is just the S8
the super-sport version of an R8 will be an RS8
simple
yes, it is- it makes 572hp
or burning
3 TT V10 RS8 prototypes have caught fire >_<
packaging and maintaining a twin turbo charged V10 engine into the relatively cramped mid engine layout of the R8 has proved to be a rather difficult thing to manage.
as sh@un said, 3(...perhaps 4) twin turbo prototypes have done thier best impression of a roman candle in testing. the most famous of which was at the 'ring, pretty much melted everything but the basic chassis... and keep in mind that aluminium has a melting point of about 660 degrees :)
current plans are to use a naturally aspirated 5.2-5.5 litre V10 producing somewhere in the region of 373kw, it should be easier to keep this set up cool.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
