Hid Globes
ali-turko
 Share
Anyone tried jumpering low beam so it stays on when you select low beam ie. all 4 lights at once shouldn't b hard to do
would be a little awkward if other cars coming the other way would b ok for trackwork at night though :rofl:
would be a little awkward if other cars coming the other way would b ok for trackwork at night though ;)
A bit off-topic, but I've thought of this as well... would be nice... but cops will notice instantly they got all four lights on at the one go (regardless of intensity) and will pull you over as it's too bright and too many nights flaring at the opposite direction.
But yeah, I would think this would look nice plus the foggies on too... :banana:
pics of foggies?
would be a little awkward if other cars coming the other way would b ok for trackwork at night though :)
I've got a wiring diagram around here somewhere, and a list of parts needed. All up was going to cost sub-$50.
*digs around*
There is a position on the switch between low and high beam where both lights lit up in my car.
If only I can make it stay there then wouldn't even need to do much modifications
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
