sorry about dodgey photoshop work! But let me know what you think about the rim against the yellow... decent tyres, kit and lowering will be made as well.
Very nice choise, especially against a yellow r34, well dats my opinion anyway..
Have u thought bout increasing it a size or 2, they seem to be 2 small for the car even when it would be lowered...
https://www.sau.com.au/forums/topic/198237-opinions-please/#findComment-3540434
lol its photoshopped, so the size wont be as you see there, im pretty sure 19's fill out r34 guards nicely with some room to move,
but yeh, they look hot, i want black rims wit a silver lip too, :) do it
https://www.sau.com.au/forums/topic/198237-opinions-please/#findComment-3540642
its been photo shopped only because when I tried the rim on, the dude couldnt lower the jack cos the rim didnt have a tyre so really its actual size, its a 19x8.5, but i know what you mean I thought the same thing about going 20's.. anyway heres another dodgey photoshop job of how id like the car to look.. look at my awesome bodykit i made haha
Edited by MellowYellow
https://www.sau.com.au/forums/topic/198237-opinions-please/#findComment-3540750
i reckon they look awesome....despite the dodgy photoshop work :)
the black on yellow cna be done to look good, especially if you get some good tints and possibly other dark parts on the car (wing etc etc)
thumbs up for me :)
https://www.sau.com.au/forums/topic/198237-opinions-please/#findComment-3543541
  • 4 weeks later...
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
