Yes, I am an idiot .. no spare key :rofl:
Can't find my key anywhere in the house (where it must be since my car is in the garage). What is the the deal if I cannot find the key at all ? Luckily the car is unlocked at least. Will I be able to get a replacement key from Nissan or have to get a whole new ignition barrel and key from a wrecker or something ? I really do not want to have to change all the door locks as well.
Stupid, stupid, stupid for not having a spare.
Any suggestions ?? Is there a serial number on the ingnition barrel or something that might help ??
Stu
https://www.sau.com.au/forums/topic/198266-help-lost-key-and-no-spare/
I believe you can take your vin no and other vehicle details (like chassis no) to any nissan dealer and they can cut you a new key using the factory specs.
I haven't done so myself but worth a call to a nissan dealer.
pull your door barrel out and go to a locksmith and they cut the key to the coding of the barrel we do it at work all the time for customers .
Thanks everyone,
I thought the key might have a transponder in it that would prevent a standard key from starting the car ?? Does anyone know if a standard key cut from the factory one will still start the car ?? (i.e. with no lock/unlock buttons)
Otherwise I guess I will be the guinea pig and get a key cut to the door lock barrel and see if it will work :rofl:
That wont work. Ever notice how a key wears down after use and eventually becomes just a flat edge with no bumps? Well, as the key wears so do the pins in the lock, meaning a brand new specifications key with highly accentuated edges will no work any more as the pins have also worn down to accept the worn key.
I would suggest you remove one of your door handles or the lock from the boot and go to a locksmith and get a new key cut that way.
sounds like taking a barrel out is the go .. there goes remote clocking *sob*
thanks dudes.
my s1 had a factory allarm fitted but i had to get an australian approved one fitted. you may have a factory fitted allarm. i had a nissan sticker on the boot window but any alarm can be fitted to overide factory and work as the primary allarm, and central locking. hope u find your key. ps if u find it a copy cost 10 bucks
Theres a 4 digit number on every key. (it may be on the barrel as well), could also be on FAST?
Just quote the number to a reputable locksmith and he will cut it using the Nissan database.
no actual key required. (yes this means there are only 10,000 key combinations)
Some compliance shops feel it's prudent to grind the number off the key.
Our number is ground off our key, but it's in really good conditon so I'm just going to get some spares cut off the one we have.
Also, there should be a 4 digit number printed or stamped on the lock barrels. Just get that and get a key cut from the code, instead of taking out the whole lock!
Cheers, Greg.
  • 4 months later...
The one on eBay Australia? That one doesn't have the central locking remote control on it, it's just a key with a Nissan plastic cover.
http://cgi.ebay.com.au/GEN-NISSAN-KEY-BLAN...1QQcmdZViewItem
dont take out the barrel, take out one of the locks from the doors or the boot lock man.
BTW for anyone whos interested, you can get a mobile locksmith to come out and cut the key without removing any locks from the car. Takes them about 1/2 hour
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
