I gotta ask - why?
The only reason the park brake gets moved in the event of a manual conversion, is because it gets in the way of the clutch (and this is the same reason the manual console carries the handbrake)
I doubt wether it will be possible anyway - you would need to put it on to a very modified auto console and there is a whole lot of stuff in the auto console that you really don't want to mess with - power/snow buttons, overdrive control switch gear, and some also have their seat movement and heater controls there, not to mention some of the oddball stageas getting around with aux power sockets etc etc etc. Then you will have to remember that the airbag sensor and attessa sensors are also under the console.....
see my point?
I gotta ask - why?
see my point?
I see you point...Just wondering if it could be done. Thanks for the advice
I think it could be done. I have converted my car to manual and fitted a handbrake. The hardest think would be to modify the auto console to suit the auto shifter and handbrake
Attached is a pic of a auto console of a car in japan that has been modified to suit a manual. It shows there is enough room to fit the handbrake in front of the storage compartment which is the main thing. On a manual console the storage compartment is shorter to allow for drink holders, as the in dash ones on auto cars, hit your hand with a manual gearbox when changing gears.
Do not try and get a manual console and modify it as they hardly existing s/hand and cost over $800 new.
A brand new handbrake and mounting bracket will cost you approx $200.
Also attached is manual console for your reference
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
