If it was for a daily only and you did not really car about much else other than reliability and fuel economy I would go for a Nissan Pulsar, Toyota Corolla, Ford Laser etc.. All four cyls so rego, insurance, running costs are cheap as.
Considering you got $10k to spend though you could look at some of the Subaru Libertys etc..
I thought manuals would be better on fuel but coz of the different gear ratios. It's easier to travel at 100klm in 5th gear than it is to travel at 100klm in the same car in 3rd gear (most auto boxes on 4 cyls are 3 gears only).
no auto are 4 speed
(Gear 1) 0-20km/h
(Gear 2) 20-40km/h
(Gear 3) 40-60km/h
(Gear 4) 60km/h to infinity and beyond
I'd recommend a lancer if you want to go a lil sportier or spend a lil on mods
and the corolla if you're on a tight budget
My daily.
Cost me $6,000 from at friends neighbour who was selling it as a trade in.
Has:
leather interior
Working Tv (factory) touch screen as well
Auto
4lt 1uzfe.
not to bad on fuel as long as you dont gas it everywhere i will get same Lt/100 as my dads Sv6 commo
and i put a dvd player in it, that cost me $70.
I have a 93 nova(corolla) so +1 for the rolla :D
I was looking for a manual hatch, but a sedan auto came up at a good price (1300) so i grabbed that. Some days i like the auto, other days id rather have a manual so i can save a bit more on fuel, probably just being cheap tho lol
Autos get worse fuel economy due to the use of a torque converter arrangement over a direct (manual) clutch engagement as a form of power transmission. In addition you generally will have another gear to play with (5sp manual vs a 4sp auto) which can make it better on fuel eco but typically the final drive for both will be the same. This is provided if driven the same way same revs etc etc.
I would go with a carolla, but only downside is that they are a tad small. Depends what your using it for as a daily. If you need to ship stuff about which is bigger than ur usual run of the mill cargo, then mayb a falcodore station wagon v6/straight 6 could be a better option. The rolla tho has excellent fuel eco, reliable as anything, aircon, and can be found under 10k.
Up to you...
Edited by R32Abuser
Can someone recommend a daily that has the following requirements;
- Good on fuel
- Auto
- Under 10k
- Aircon
- Not classed as a "girls car" :blink:
mitsubishi magna, '02 onward :) , they go ok, cheaper on juice than most 6cyl cars and respond well to rice :rofl:
corollas are girls cars btw :P
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
