[hi guys im about to purchase i set of heqdlight and i was after these, no i want to know if these are genuine n1 headlighhts, they are gioing on my r32 gtr but just wanted to make sure they are the genuine n1, please let me know asap people, any help would be thankful
cheers guys
does it have the brackets for the grill?
if not its gts headlights.
yer on the add it says doesnt have the grill brackets, so does that mean they are gts headlights :blink: , i looked at gts headlights and they dont look like this, anyway more help will be good but thanks anyway
probably wrong forum section to post this try general car chat rooms you may have more luck getting an answer.
this is the for sale section.
Ok, standard GTR lights are projector, as are some GTST lights (m spec etc) - there is no difference between a projector headlight from a GTR or GTST
N1 lights are not projector however, to save weight... N1 is for motorsport remember.
So weather their GTST or GTR is besides the point as they are interchangeable... and as long as they aren't someone just painting the inners they are fine.
FFS those are poverty pack headlights in those pics, not N1. probably worth less than projectors.
Whats the give away if you don't mind me asking, I'm gonna be looking for a set myself in upcoming months.
proper N1's have a different dffusion pattern on the glass, the outer light's reflector is longer as well. plus they're rare as rocking horse shit. even N1 GTR's didn't get them standard, they were optional.
lots of people jam GTR grille mounts (which cost about $25) onto standard headlights and sell them for a lot more than they're worth.
you're thinking N1 headlights anfd GTR headlights... I guess they're both GTR's but N1 headlights are a lot more expensive and rarer. Two Square = N1, Square + Round = GTR.
There's a lot of Square + Rounded Square goin around which are 1989 pov pack headlights off Type G's. A lot of people think these are N1 but they're not.
Found an old post of yours, clears it up for me, cheers :whistling:
Contact Nissan. Once you see the price they want, I'm sure you'll just want to purchase the cheapo gts lights and modify them to fit the grille, etc.
nar mate i wouldnt get these 1s, i know someone that gets genuine n1 headlights for $350-$400 but these ones here i could of got for a beetter price, thansk alot for the helb buddy,
cheeers
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
