For this guys who are looking to install a fire extinguiser for track days,
read ahead!
Make sure you have a CAMS approved Fire extinguisher and it is in its current date/charged etc
All you'll need is a 12mm socket to undo the bolt. And a drill to drill the hole in the metal extinguisher bracket to make the hole slightly bigger.
After doing a few searches and talking with Duncan and Sam916 - this was prob the best place we could think of, its still in reach from drivers seat while seat belted in (which is a CAMS requirement)
I have my back seat out, so I dont know how it goes with backseat in...
Thats the bolt on the passenger side of the back seat. Just get the 12mm socket, take her out!
Drill the hole (note - I cannot remember size, however best to start small and if the bolt still doesnt fit, go to a bigger drill)
You need the nozzle/top of the extinguisher facing towards the left of the car. So make sure you drill into the top hole in the metal bracket.
Tats it fitted!
Do the bolt up tight. We did it up tight and tried to budge it, sits in quite secure.
Cheers,
Chris
https://www.sau.com.au/forums/topic/198337-r33-fire-extinguisher-instal/
Dammit.
I double posted :blink: hahahaha this thread is in general maint section - can a mod please merge posts? Cheers!
James, I got this one from Auto1
the whathisface?...umm....
not bad, I'm a bit worried that it's only held in by a single bolt.. i'd prefer two for safety.
what about under the driver's seat? I've seen examples of making a bracket up and it looks fairly straightforward. Not sure if you can strictly reach that with the seatbelt on tho.
Geoff!!
Mate,
have you seen the two little holes that they come with (the bracket)? they dont even look secure! :D
Once you do the bolt up really tight, I tried to budge it, make it move etc and it was dead tight (and Im heaps strong!!!lol)
Ask Sam! :)
Dammit.
I double posted :) hahahaha this thread is in general maint section - can a mod please merge posts? Cheers!
I meant the thing that holds the extinguisher? same place?
Ask Sam! ;)
Chris, what you guys get up to in your own time is your business and yours alone :banana:
the standard bolt holes do look pretty pissweak, but if you had a shunt an extinguisher is heavy and i can see it twisting the bracket and maybe popping out and flying around looking for you. maybe at the speed that happens you've got other things to worry about but better to err on the safe side!
hope things are well anyway.. I haven't seen any skyline peeps in months :)
  • 5 months later...
  • 3 weeks later...
hey Casbo..
have u got anymore phots of this install???
got my extinguisher for my 33 now..just stilll wondering wer to put it...
wer about is urs?have u got anymore photos???
thanks
I don't have any more photos right now, but I can take some pics tomorrow :D
The photos I took where taken from in between the front seats with me being in the driver's seat.
  • 1 year later...
That was a long next day :D
Any who, I took some pics as evil_weevil's ones have stopped working. Figure I might also do a bit of instruction while I'm at it.
Step 1.
Go to your local Autobarn / Supercheap / Repco / where ever. Take a look at what fire extinguishers they have. You are looking for 3 things
1. Over 0.9 kgs
2. AS1841.5 sticker
3. Pressure still in the "green"
4. Comes with a bracket.
Here are some pics of what I mean.
I bought my extinguisher for around $30 so I imagine that yours will cost a similar amount.
Step 2.
Pull the extinguisher out of the box and separate the bracket from the extinguisher.
Step 3.
Drill the mounting hole furthest from the bracket's latch out to at least 8mm. I drilled mine out to 9mm to give me some margin to play with when I finally mount it.
EDIT
Be careful when drilling as the drill can grab the thin metal of the bracket and force it out of your hands, usually giving a good gouge in the process. Use a vice or stand on the bracket like I did lol
Step 4.
Undo the bolt that holds down the passenger side of the rear seat.
Step 5.
Bolt bracket to rear seat mounting point.
Step 6.
Put extinguisher into bracket
Step 7.
Rip skids
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
