Hey guys
Just after some options to plumb in my bov back into the intake, which is repositioned over near my plenum.
I have seen krazy or crazy's engine bay ( orange r33) with the polished alloy or steel pipe going across the radiator
but was just seeing if there were any other options that i could look at.
In my own mind i couldnt of cared less if it was plumbed in or not, but i then i dont want to get defected so.
Also i have fitted a xf throttle body on a custom made plenum, and just to let people know the r31 accelerator cable is long enough and works.
will have it on the road next week.
https://www.sau.com.au/forums/topic/198357-pics-of-plumb-of-bov-options/
Just have the BOV before cooler, and plumb into the intake from there.
Lot easier, lot less dicking around.
I have a RB26 BOV setup used in that manner, works fine in the 1000km's or so that ive done now, no issues to report other than its noise cause i have pods
Even though its not factory (ie, after cooler where the BOV's feed from), seems the goods.
Cheers.
only problem the bov has been already been fitted just after the throttle body
so it looks like running a alloy pipe from that side to the intake is my only option. But was just seeing how people have done their pipes.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
