guess my next question is if the worst was suppose to happen would you
a) lose your license and serve the 3 month suspension
B) keep your license and go on a good behaviour bond for 12 months and drive like a grandma sunday driver.
c) lose your license and still keep on driving only for emergency ofcourse....oh did i say that .
Basically.. I'd take option a) with a possible c) option if you're brave. 12 months of hell and feeling stressed every minute you are driving wouldn't be worth it if you ask me.. 3 months wouldn't be easy but it could be done.
In this era of revenue raising, if you ask me its almost impossible not to let your mind slip just once in 12 months of driving. Its b.s.
Guest wilco
I was booked running an Orange because the cop said I sped up to go through the light when I should have stopped. I entered and exited the intersection on an orange light.
The cop ran a red light whilst speeding to book me though, so who was the more dangerous!
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
