Item:RB25det Apexi Power Fc with Hand controller SOLD
Price:$1350
Item:Blitz 60mm water temp AC gauge with sender SOLD
Price:$120
tem:Tein C spanner SOLD
Price:$40
Item:Hella Horns 110db
Price:$40
Item:stock bov SOLD
Price:$35
Item:Nissan Original single din pocket SOLD
Price:$20
Item:R33 Leather Gearboot and handbrake boot
Price:$25
Item:associated stickers
Price:HKS $5, Advan $5, ARC $6, Nismo $6, Apexi $12 , warning $6
Item:Mtec H3 100w 4,750k
Price:$25
Comments:All prices excluding delivery
Edited by Giveitall
If the DIN pocket fits an R33 Series 2 GTST, i'll snap that straight up. $20 + postage to Canberra (post code 2603)
I bought it for R33 series 2 and it fits perfectly. They are actually universal if they are orginal nissan. it is as new condition too.
  • 1 month later...
