hey ppl!
merry christmas and a happy new year to all!!! :D
i am planning to powder coat my set of rims. and the powder coater says i need to remove the sticker myself.
do u know how to get them out without damaging them??
if anything goes wrong i might need a new sticker - can i get this anywhere?
its a work emotion rim n as usual they have the sticker on the spoke and on the inner rim (offset and size etc)
could any one guide me....
thanks!
https://www.sau.com.au/forums/topic/198389-removing-rims-sticker/
Only thing I can think of doing to help not damage the sticker is to use some sort of heat gun or hair dryer to 'melt' the glue behind it. Then slowly peal it off. I'm assuming that if the sticker is old, it'll crack and fall into pieces which you can't really do anything about it.
Edit: Merry Christmas and have a happy new year to you too!
Edited by adam-__-
Hmm... nope, not likely you'll be able to get a sticker off & save it.
Probably better to take a rim down to your local sticker guy & get him to make some up for you before you peel them off.
Take some pics of the wheels as they are now too, just in case you want to sell them in the future, you can show they are genuine Work & not just no name wheels with stickers that look the same.
You'll pretty much have to live without the size/offset sticker on the inside (unless you're keen enough to get them made too), just take a photo or write all the info down for future referance.
Wax & Grease Remover (from most auto shops) on a rag will do the trick, fairly wet, & let it sit on the sticker for a minute to soften it up... might need a little scrape with a razor blade too (definatley not 'save-able' this way) .
Cant you just cover it during powdercoat then remove the cover afterwards?
Nope, powdercoating requires the item to be baked at 250 degrees (or 300 or something, its pretty hot anyway).
The wheels (or whatever) get chemically cleaned then spayed with a powdered pigment, (actually looks like a bag full of coloured powder, sprayed through a special electrostatic gun which makes it wrap around into all the little edges & corners)
then put into an oven to bake. This 'melts' the powder together to form the end coating.
Try to find a good recommended powdercoater that does wheels too. Some of the fence/steel powdercoat guys are be pretty rough.
thanks guys!
tats wast the guy said... cant leave it on n remove it later. need to be soaked in chemicals n baked.... so basically = dead stickers.
the rims are brand new never been used b4.... couldnt find one in black so gotta powder coat it... i will tryi to slowly peel it off with a hair dryer first, see if tat could work.... if not too bad....
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
