Hey all,
Have sold the GTST and now im looking at a gtr...
Boostworxs have been great to me and helped out heaps. but they only have a 2wd dyno....
So now who do you guys use that are reptuable and trusted for tuning etc of the 4wd cars?
Cheers
ps off topic... are n1 turbos standered gtr 33 turbos?
Edited by Adz2332
https://www.sau.com.au/forums/topic/198423-tuners/
how do they do it seeing as they only have a 2wd dyno??
drop the front driveshaft, pop the fuse, do the tune then get it ready for pickup.
I used to go to GWW but I feel boostwerx look after me with service and price
https://www.sau.com.au/forums/topic/198423-tuners/#findComment-3543092
ahh excellent and boostworxs will drop the shaft etc no probs? does it cost any more?
There happy to do it?
Id be reali happy to keep using them!!!!
https://www.sau.com.au/forums/topic/198423-tuners/#findComment-3543096
You dont need to do any mechanical mods to GTR's to dyno on 2wd, just pull out the ATTESSA fuse and the car goes to 2wd. Besides the dynotune is working on the engine, only needs one set of feedback from the rears to work (the only benefit in getting a 4wd dyno is that you can compare the power loss from the front driveshaft/diff assembly.. same way u can get it dynoed at the flywheel or the rear wheels, its just a question of application.)
If you're north of the city, I'd recommend Road & Track in collins st, enfield, their dyno guy Mikey has done excellent work on my gtr, from pulling 15 more kw out of thin air to getting rid of power sags. If you're down south tho, boostworx is the way to go (ive never been there but given the feedback on this board, he knows his stuff and doesnt charge an arm and a leg for it)
-D
https://www.sau.com.au/forums/topic/198423-tuners/#findComment-3543165
It's only on R32 GTRs that you can pull out the fuse to make them RWD. With R33 & R34 GTRs you to have drop the front driveshaft.
N1 turbos were made for all GTRs but are only standard on N1 or Nur GTRs. The R34 N1s are the only N1 turbos that have steel wheels instead of the ceramic exhaust wheel. There are also 3 different types of R34 GTR N1 turbos. You will find alot more info on them in the Forced Induction section.
https://www.sau.com.au/forums/topic/198423-tuners/#findComment-3543240
so how will i be able to tell what ones they have on the car?? just by looking at them?
And they are a slight upgrade from standered?
https://www.sau.com.au/forums/topic/198423-tuners/#findComment-3543253
-D
I've had free horsepower before as well at other places.........the problem is, the way they usually get is by tuning your ECU to the point where they thin out the AFR's too much to the point of Too Lean and sometimes Detonation.......I always prefer slightly conservative tunes and my engine thanks me for it.
CORRECT.
https://www.sau.com.au/forums/topic/198423-tuners/#findComment-3543446
you will have to get the serial numbers from your turbo's. Iam running R34 N1 turbo's "Garret 2860r-7" on my GTR and pulling 314rwkw on 20psi. Tuned by Boostworx.
Ryan
https://www.sau.com.au/forums/topic/198423-tuners/#findComment-3543550
Ryan
That's interesting.........I've got some -5's ready to go on with a PFC, full fuel, cams and intercooler upgrade so I'm hoping to pull at least those figures myself. Oh.....and a Kakimoto full dual N1 exh.
Did you have to do many other mods to get those figures?
https://www.sau.com.au/forums/topic/198423-tuners/#findComment-3543862
Serial numbers and specs can be found here: http://paulr33.skylinesaustralia.com/docs/gtr-turbochart.htm
https://www.sau.com.au/forums/topic/198423-tuners/#findComment-3544626
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
