  • Replies 42
I dont know something like 500hp
This is from a spreadsheet i made when buying my fuel pump, i cant recall where the info came from.
- Bosch 040 - 235 L/hour
- Bosch 044 - 330 L/hour
- Bosch 910 - 200 L/hour
- GTR pump - 190 L/hour
- GTST pump - 135 L/hour
Like i said this is from an old spreadsheet, i cant recall where the figures came from, or the integrity of them.
The 910 can be mounted as an internal pump as well I believe.. i think if all you want is a "replacement" and aren't planning more than 450hp (which is something like 280rwkw)..the 910 would be fine.. save the $
I picked mine up for $200.. yet to go in as its a bit of a bitch getting the cover off to get into the tank itself. Haven't had a few hours spare to sit down and work out how its all to go in..
might be able to give you a hand fitting it - or you can come and give me a hand when i try and do mine :D
If you are chasing upto 250rwkw, go the GTR pump, they fit where the stock one does and minimal stuffing around.
I just put in a 044, what a pain in the arse. Had to chase around for hours to get all the mounting adaptors hardware, then had to hack saw the bracket to fit the pump, then bend the bracket to fit it into the tank and it still didnt go in easy. I would estimante a stock pump to gtr would take 1 hour tops, 044, with all the stuffing around (trying to find the parts, then actually getting them) took the best part of a day.
Or, just put a bosch pump in line.
A friends 200SX is supposed to have an 044 pump in its tank. There are bladder type syphons that can be screwed into the pumps pick up so that they can still be used in tank. Can anyone else confirm this?
As for the noise, be prepared they are noisy, me i think they sound cool, but i know it gets on the nerves of the cars owner, and if pulled over by Police could be a point of concern.
Oh and one other thing, my insurance company stipulates im free to have mods to whatever, except my fuel system must remain original.
If this is a smart way of ensuring a HP ceiling, or arises from a safety/fire perspective i dont know. But with a pump whining away when car is running i wouldnt want to be the person explaining the noise to the assessor.
Thats my thoughts anyway.
You can use the pickup from the stock pump, just have to remove the tag that secures it to the stock pump (its plastic and sidecutters and stanley knife do a nice job), then use a piece of 1/2" hose from the bottom of the pump to the pickup and a couple of clamps.
You also need the fitting to go in the bottom of the pump and these are pretty rare but I found one at a speed shop, then you need a hosetail connector to go on the fitting to attach the 1/2 inch line.
You also need a banjo connector for the top of the pump, and some 3/8 fuel line to replace the existing stuff cos its too small and hose clamps. A couple of wire connectors, an 8mm and 10mm nut, stainless hose clamp to secure the pump to the bracket, but you could probably use cable ties if you are in a bodgey mood.:D
The pump ends up alot higher on the bracket so the pickup is in the right spot, so you need to bend the two tongues that secure the bracket to the (edit) tank, as the extra girth of the pump over stock prevents the tongues locating in the bracket.
If your insurance company wants you to keep a stock fuel pump, try a GTR one, I doubt very if an insurance inspector would know the difference between it and a stock one. then just get an adjustable nismo fuel pressure reg, cos apart from the adjust bolt on the top, they look stock and fit in the stock position. Something to think about anyways.:D
Im with client, my 044 in my 32 went in no worries at all, under an hour as well...I could do it after seeing it done in say 30...Just make sure when u get it done, u only have say 1/4 tank etc.
With my 044, i only notice the noise when its a *hot* day,
apart from that, i get this shit circulating noise every say 30sec/min, sometimes it doesn't happen for 10min, but it sounds ghey :)
In regards to needing a tune, is this likely?
How do u 'dial in a new pressure' :)
Originally posted by Steve
No they are not.  Why do you want rising rate?  Just dial in the pressure you want, and adjust the pulse width to suit.
True...
I assumed after seeing Malpassi Adj. Rising rate fuel pressure reg's that they were the go. When Running really high fuel pressure to get the most out of your injectors wouldn't it be better to have a rising rate to reduce the stress of extra fuel pressure when just plotting around on low to medium boost?!?!
Brody...
I get that same crap noise on hot days with my Boch 910 external pump. I really don't like that sound.. What actually causes it? Surely it wouldn't be vapour locks?!?!
Joel, if it wont take the stress all day every day, you shouldnt be using the pressure, or at least upgrading fuel lines etc. I would hate to try and stretch my fuel system even close to limits, 'cos all it would take is a tiny hole, either running lean, or fuel vapour floating around - not sure which I would like less? If you are in doubt, perhaps its time to replace all the feed lines?
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
