Dont know if anyone has had this problem but when i turn my key to the 'on' position, none of the lights come up on my dash. The stereo works and the turbo timer works as does the alarm but windows and sunroof dont. They car cranks over but doesnt start. Usually when the all the lights come on you can hear it power up, this time theres nothing. Checked all fuses and nothings blown. Is it possible that something is loose that i should be looking for? The car was drivin an hour earlier aswell.
https://www.sau.com.au/forums/topic/198464-need-help/
sounds like you car isn't really turning to the "ON" position. the key might be in the ON position but the car isn't powering up to ON.
check the positive battery terminal connector, there will be your large core (main) cable and also some smaller wires on plugs, check the smaller cable haved become unplugged.
if thats all good the check to see if you have a constant power source to the ign barrell, and that it is powering up the "ON" position wires.
https://www.sau.com.au/forums/topic/198464-need-help/#findComment-3544019
Theres heaps of wires around the battery, is there one in specific or just check all in general? Im on holidays from tomorow so ill pull around the steering wheel apart and have a look. Just wanted to see if anyones had this problem before and knew exactly what it was, not sure if its common or not.
https://www.sau.com.au/forums/topic/198464-need-help/#findComment-3544252
Have you checked the main fusible links (big fuses) as it sounds like you may have blown one of these. These are located in the engine bay near the water bottle on the drivers side under the black cover.
Cheers,
Ben
https://www.sau.com.au/forums/topic/198464-need-help/#findComment-3544687
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
