Today I was unfortunate Enough to be caught out in that crazy storm and flash floods, and I assuming quite a few other members would have been to. I was in one of the Areas that was Copped it the worst, that being Highhett/Clayton. Now I just wanted to know how bad it is to be driving in flood water thats almost up to bonnet when u have a turbo car? I would have taken loads into the Intercooler, which i imagine couldnt be healthy for the car. after the rain cleared and i was on open road, I noticed the car blurting and jerking when i stomped it in second gear. should i get this checked out immediatly or just chill?
P.S Missing.. a front wheel arch guard, last seen floating down Nepean Hwy. PM if found.
Edited by Gazzilla
https://www.sau.com.au/forums/topic/198471-using-your-car-as-a-boat/
Why would it have taken water into the cooler? They are sealed dude...
Air-to-air coolers use air to cool the air INSIDE. Therefore sealed :whistling:
If the piping wasnt sealed, you'd have a leak and boost drop issues, and notice it long before it filled with water in everyday life.
know what shits me the most ever?
those people that have a sticker/spare tyre cover that says "my other car is a boat"
a car is not a boat. a boat is a boat. a car is a car.
lol.... the 49% bitch 51% angel, dont push me stickers annoy me more
Edited by NORBY
have you got any sort of cold air intake that could have sucked the water up?
speaking of which...how likely is it that your pod would suck in water if you've got a cold air intake pipe running up to the hole where the factory 'cold' cooler pipe would usually be?
after driving in some heavy rain lately, i had a look and found a small amount of water pooled up in that area. i didnt think it would actually get sucked up into the pod, its a good few inches away.
+1 on pod suckin up water if you have one. check you coils and electrics. see how the car runs the next couple days.
a couple years ago i drove through a flooded patch at the glen on springy rd in the parents new corolla. blind leading the blind..ha thought id be right untill the water started going over the bonnet..ha. water got into the headlights...there was some wierd corossive looking foamy pink stuff surrounding the coolant/radiator. will never ever drive through a flooded patch of road again even though others will.
Unless you had a prior leak somewhere else the only place i can think you'd get water is through the pod.
Similar thing happened to me with the Commodore a while back (spluttering and coughing), just drove it easy for a bit and the water will work its way through....
The only other thing could be some sort of elec damage....
I drove home in the worst of it ystrday in the aaah, love the traction BUT, the windscreen wipers are too damn slow, couldnt see shit, ima have to put some new motors in or something, these suck ass!
Also wish i had taken the rolla in, that thing loooves the puddles (well.. i make it love them)
Edited by GTAAAH
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
