Today I was unfortunate Enough to be caught out in that crazy storm and flash floods, and I assuming quite a few other members would have been to. I was in one of the Areas that was Copped it the worst, that being Highhett/Clayton. Now I just wanted to know how bad it is to be driving in flood water thats almost up to bonnet when u have a turbo car? I would have taken loads into the Intercooler, which i imagine couldnt be healthy for the car. after the rain cleared and i was on open road, I noticed the car blurting and jerking when i stomped it in second gear. should i get this checked out immediatly or just chill?
P.S Missing.. a front wheel arch guard, last seen floating down Nepean Hwy. PM if found.
Edited by Gazzilla
https://www.sau.com.au/forums/topic/198471-using-your-car-as-a-boat/
Why would it have taken water into the cooler? They are sealed dude...
Air-to-air coolers use air to cool the air INSIDE. Therefore sealed :whistling:
If the piping wasnt sealed, you'd have a leak and boost drop issues, and notice it long before it filled with water in everyday life.
know what shits me the most ever?
those people that have a sticker/spare tyre cover that says "my other car is a boat"
a car is not a boat. a boat is a boat. a car is a car.
lol.... the 49% bitch 51% angel, dont push me stickers annoy me more
Edited by NORBY
have you got any sort of cold air intake that could have sucked the water up?
speaking of which...how likely is it that your pod would suck in water if you've got a cold air intake pipe running up to the hole where the factory 'cold' cooler pipe would usually be?
after driving in some heavy rain lately, i had a look and found a small amount of water pooled up in that area. i didnt think it would actually get sucked up into the pod, its a good few inches away.
+1 on pod suckin up water if you have one. check you coils and electrics. see how the car runs the next couple days.
a couple years ago i drove through a flooded patch at the glen on springy rd in the parents new corolla. blind leading the blind..ha thought id be right untill the water started going over the bonnet..ha. water got into the headlights...there was some wierd corossive looking foamy pink stuff surrounding the coolant/radiator. will never ever drive through a flooded patch of road again even though others will.
Unless you had a prior leak somewhere else the only place i can think you'd get water is through the pod.
Similar thing happened to me with the Commodore a while back (spluttering and coughing), just drove it easy for a bit and the water will work its way through....
The only other thing could be some sort of elec damage....
I drove home in the worst of it ystrday in the aaah, love the traction BUT, the windscreen wipers are too damn slow, couldnt see shit, ima have to put some new motors in or something, these suck ass!
Also wish i had taken the rolla in, that thing loooves the puddles (well.. i make it love them)
Edited by GTAAAH
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
